Rear arms |
Rear arms |
Blue6 |
Jan 9 2015, 11:05 PM
Senior Member Group: Members Posts: 1,035 Joined: 3-October 13 From: SoCal Member No.: 16,470 Region Association: Southern California |
Are the rear arms from all years the same/ interchangeable? My car is a '70, and my spares that I've been rebuilding, strengthening, welding tie downs on, are from an unk yr. Hope I haven't waisted my time.
ClayPerrine |
Jan 9 2015, 11:27 PM
Life's been good to me so far..... Group: Admin Posts: 15,498 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
They are all interchangeable.
bdstone914 |
Jan 10 2015, 10:55 AM
bdstone914 Group: Members Posts: 4,529 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
They are interchangeable but not the same. Early arms have a shorter bracket for the brake line that uses different mounting hardware and flex lines. Use the matching flex lines. Early arm brackets have a hole and late arms have a slotted hole. They also lack drain holes that later arms gave.
Eric_Shea |
Jan 12 2015, 10:55 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Early arms also have a solo tab welded on the left arm. This is because the arms were shared on the 914-6 and that tab (along with a blue cloth strip and a screw) held the handbrake cable away from the heat exchangers.
They all work though, just remember when you need new soft lines to get the early models or the late... depending. |
Lo-Fi Version | Time is now: 31st May 2024 - 07:21 PM |
