> distributor-less ignition, where to go
02loftsmoor
post Jan 10 2015, 01:40 PM
Post #41
I'm check on going with distributor-less ignition system, some pointers please
02loftsmoor   distributor-less ignition   Jan 10 2015, 01:40 PM
McMark   Micro squirt running ignition only would be my rou...   Jan 10 2015, 01:49 PM
jarred   A slightly self-serving reply... I vote megasquir...   Jan 10 2015, 01:55 PM
DBCooper   A slightly self-serving reply... I vote megasqui...   Jan 11 2015, 09:41 AM
stugray   You could use a MSD with crank trigger and coil-on...   Jan 10 2015, 01:58 PM
mikesmith   I'm check on going with distributor-less igni...   Jan 10 2015, 02:12 PM
02loftsmoor   I'm check on going with distributor-less ign...   Jan 11 2015, 09:29 AM
mikesmith   Knowing what your goals are would help folks mak...   Jan 11 2015, 12:58 PM
jarred   Quick correction: the megajolt only uses a 36-1 tr...   Jan 11 2015, 10:46 AM
stugray   Quick correction: the megajolt only uses a 36-1 t...   Jan 11 2015, 01:52 PM
WLD419   For twin spark on a megsquirt based system you wo...   Jan 15 2015, 05:47 AM
Harpo   Clewett offers a system. Although it is for 4 plu...   Jan 11 2015, 02:30 PM
jarred   Stugray: I've looked into developing the compu...   Jan 14 2015, 02:18 PM
stugray   Stugray: I've looked into developing the comp...   Jan 14 2015, 05:41 PM
veekry9   http://rusefi.com/wiki/index.php?title=Main_Page Y...   Jan 14 2015, 05:47 PM
jarred   Interesting. Not sure if you looked at my advert,...   Jan 14 2015, 06:09 PM
stugray   The simple MSDs require a tach signal that represe...   Jan 14 2015, 07:53 PM
PotterPorsche   http://www.cbperformance.com/ProductDetail...roduc...   Jan 15 2015, 12:07 AM
Jake Raby   I go Electromotive. You can either buy a Tec-S and...   Jan 15 2015, 12:58 AM
Mark Henry   I don't know why you would bother doing this u...   Jan 15 2015, 06:10 AM
02loftsmoor   I don't know why you would bother doing this ...   Jan 15 2015, 01:43 PM
Mark Henry   [quote name='Mark Henry' post='2134266' date='Jan...   Jan 15 2015, 03:52 PM
stugray   Ok, timing is important, you need a good curve, b...   Jan 15 2015, 05:59 PM
Mark Henry   Ok, timing is important, you need a good curve, ...   Jan 15 2015, 08:58 PM
stugray   If you think you are charting new territory you a...   Jan 15 2015, 09:43 PM
Mueller   I don't know why you would bother doing this ...   Jan 19 2015, 01:03 PM
Mark Henry   I don't know why you would bother doing this...   Jan 19 2015, 01:18 PM
veekry9   [quote name='jarred' post='2132700' date='Jan 11 ...   Jan 15 2015, 01:01 PM
rdauenhauer   @WLD419 who did you twin plugging/headwork? Edit: ...   Jan 15 2015, 01:27 PM
jarred   Mark: Theory is that accurately timed/mapped spark...   Jan 15 2015, 01:40 PM
veekry9   [quote name='Jake Raby' post='1961816' date='Nov ...   Jan 15 2015, 02:03 PM
veekry9   RoJfMZ9YgQc http://www.914world.com/bbs2/index.ph...   Jan 15 2015, 04:35 PM
jarred   I suppose it depends on what "complicated...   Jan 15 2015, 04:57 PM
Mark Henry   I suppose it depends on what "complicated...   Jan 15 2015, 08:42 PM
jarred   They're getting closer http://msdroid.com/   Jan 16 2015, 02:41 PM
stugray   That is almost identical to what I built (droid ph...   Jan 16 2015, 04:23 PM
Mark Henry   Hate to say this but...bluetooth on a 50 year old ...   Jan 17 2015, 10:27 AM
stugray   Hate to say this but...bluetooth on a 50 year old...   Jan 17 2015, 11:37 AM
Mark Henry   I understand why, but to me if you do want to go t...   Jan 17 2015, 11:59 AM
stugray   I agree with you. However with the dist.s we have ...   Jan 17 2015, 12:33 PM
WLD419   There is this , use your distributor in locked mod...   Jan 17 2015, 07:02 PM
Mark Henry   There is this , use your distributor in locked mo...   Jan 18 2015, 11:37 AM
jarred   Very true. Not sure how that works. [quote na...   Jan 19 2015, 11:09 AM
Mark Henry   Very true. Not sure how that works. [quote na...   Jan 19 2015, 12:28 PM
jarred   Cool that the CB box under $200. I agree wit...   Jan 18 2015, 10:39 AM
Madswede   I'm a few days late and several dollars short ...   Jan 18 2015, 06:24 PM
Mark Henry   I'm a few days late and several dollars short...   Jan 18 2015, 06:38 PM
jarred   Ford also did EDIS control for 4's and 8's...   Jan 19 2015, 10:36 AM
DBCooper   Ford also did EDIS control for 4's and 8...   Jan 19 2015, 11:36 AM
- Lo-Fi Version Time is now: 13th July 2025 - 06:06 PM
