fuel tank lines question |
rosenfe |
Jan 14 2015, 10:24 AM
Senior Member Group: Members Posts: 549 Joined: 14-October 13 From: northern california Member No.: 16,512 Region Association: None |
on my 73,im assuming that the larger copper line with screen in tank is the supply line and that smaller copper line is the return and that if i have carbs,the smaller line is not needed., and can be blocked off.?
rhodyguy |
Jan 14 2015, 10:40 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,081 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Correct. A piece of modern fuel line, a shouldered bolt w/clamp and you're good to go.
Kansas 914 |
Jan 14 2015, 10:46 AM
Correct. A piece of modern fuel line, a shouldered bolt w/clamp and you're good to go. (IMG:style_emoticons/default/agree.gif) While there are more elegant ways to do this - I did the exact same thing years ago. Like any fuel line inspect the clamped line regularly. |
Larmo63 |
Jan 14 2015, 10:53 AM
So, I only need to have the single line from tank to the rear of the car….?
JawjaPorsche |
Jan 14 2015, 11:22 AM
brant |
Jan 14 2015, 11:53 AM
914 Wizard Group: Members Posts: 11,625 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
A return line with carbs keeps fuel cooler and helps with boiling in extreme heat.
PanelBilly |
Jan 14 2015, 05:48 PM
914 Guru Group: Members Posts: 5,807 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Check my gulf blue thread. I just posted a photo of the regulator I i stalled for the carbs. I've got a feedi e from the gas tank and a return line back to it. Fuel will continue to circulate and the regulator pulls off what's needed for the carbs. Keeps the fuel cooler and stirs the tank
colingreene |
Jan 15 2015, 03:08 AM
Senior Member Group: Members Posts: 729 Joined: 17-October 13 From: Southern California Member No.: 16,526 Region Association: Southern California |
I just put both in, that way if i ever swap to something injected and overhead cam....
mtndawg |
Jan 15 2015, 06:44 PM
Member Group: Members Posts: 414 Joined: 26-January 09 From: Granite Bay, Ca Member No.: 9,985 Region Association: None |
Not to bogart your thread, but...do you run 9mm line from the tank to the soft line that goes into the tunnel then use 7mm in the engine bay?
bdstone914 |
Jan 15 2015, 07:07 PM
Not to bogart your thread, but...do you run 9mm line from the tank to the soft line that goes into the tunnel then use 7mm in the engine bay? I measured a supply nipple and it measured 10mm O.D. The return nipple was 8mm. This would be the case for 70-74 cars and 75-76 cars used 10mm on both gas tank nipples. Lines for the engine compartment are 8mm for the fuel loop hoses. |
Lo-Fi Version | Time is now: 20th May 2024 - 04:35 PM |
