Build thread on this 914 with an Acura V6 in it? |
Mueller |
Jan 15 2015, 02:27 PM
http://www.dailyturismo.com/2014/09/5k-leg...orsche-914.html
Motor looks good in there, no idea if it ever ran or not.... |
Jan 15 2015, 03:29 PM
Seems like a lot of work for 200HP ...
(IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/popcorn[1].gif) |
Mueller |
Jan 15 2015, 04:38 PM
Seems like a lot of work for 200HP ... (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/popcorn[1].gif) Still cheaper than a 3.0 or 3.6 P-motor (IMG:style_emoticons/default/smile.gif) |
Jan 15 2015, 04:41 PM
Seems like a lot of work for 200HP ... (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/popcorn[1].gif) Still cheaper than a 3.0 or 3.6 P-motor (IMG:style_emoticons/default/smile.gif) Not really. If you stick with a 3.0L or 3.2L motor, you don't need a front mounted oil cooler so the engine is a more or less simple plug and play. (IMG:style_emoticons/default/shades.gif) |
bigkensteele |
Jan 15 2015, 05:41 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
Seems like a lot of work for 200HP ... (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/popcorn[1].gif) Still cheaper than a 3.0 or 3.6 P-motor (IMG:style_emoticons/default/smile.gif) Not really. If you stick with a 3.0L or 3.2L motor, you don't need a front mounted oil cooler so the engine is a more or less simple plug and play. (IMG:style_emoticons/default/shades.gif) I have been told you need a cooler for anything over a 2.4 if you want to do any track time. I am building a mild 2.7 (target 200 hp). Do I need a front cooler if I want to do DEs? |
damesandhotrods |
Jan 15 2015, 05:42 PM
Senior Member Group: Members Posts: 568 Joined: 26-September 10 From: Santa Cruz California Member No.: 12,218 Region Association: Northern California |
I would imagine that the Porsche 3 litre or 3.2 litre conversion would have a higher resale value, and be easier to sell…
76-914 |
Jan 15 2015, 06:29 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,504 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
The Suby EZ30D gives you more HP n Torque than that V6. Why that gaudy assed scoop? No question the P6 is an easier install and no arguments regarding resale value. But you'd be hard pressed to do a P6 cheaper, day in/day out, than a non-exotic conversion. Mine was in the 4-5K range.
Jan 15 2015, 07:23 PM
I have been told you need a cooler for anything over a 2.4 if you want to do any track time. I am building a mild 2.7 (target 200 hp). Do I need a front cooler if I want to do DEs? I know of several street driven 3.2L conversions that run just fine with just the stock cooler on the engine. That's during the summer here in California. For a track car, i would most certainly recommend a front mounted cooler for any size engine. Knowing Mike, i don't think he was asking about building a track car ... (IMG:style_emoticons/default/shades.gif) |
Larmo63 |
Jan 15 2015, 08:18 PM
That rear "whatever" he has, on a 914, looks like schat. Embarrassing.
Zimms |
Jan 15 2015, 08:33 PM
Senior Member Group: Members Posts: 1,413 Joined: 11-February 06 From: Michigan Member No.: 5,565 Region Association: Upper MidWest |
Jan 16 2015, 04:28 PM
Custom Member Group: Members Posts: 24,577 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
just starting to see Prius motors and trans packages on the internet for sale.
I bet you could beat 60 mpg in a 914.... |
Lo-Fi Version | Time is now: 21st May 2024 - 01:13 AM |
