BENBRO02 |
Member ![]() ![]() Group: Members Posts: 485 Joined: 6-March 15 From: Nokesville, Virginia Member No.: 18,493 Region Association: MidAtlantic Region ![]() ![]() |
@spoke
Can I add front euro with blanking (does this mean the white portion turns off when you activate a directional) and not effect the dash light if I keep incandescent bulbs in the rear? |
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,243 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
@spoke Can I add front euro with blanking (does this mean the white portion turns off when you activate a directional) and not effect the dash light if I keep incandescent bulbs in the rear? @BENBRO02 In general, converting to LED turnsignals will mess with your flasher relay. Do you have an early (separate L and R indicators) or late (single L/R indicator) tach? In either case, when you change to LED turnsignals, the flasher relay will not behave properly with the tach indicators. You need to swap out the OEM flasher relay with a modified EP26 LED-compatible flasher relay. About the Euro front turnsignals, yes the white LEDs shut off when the turnsignal is active on that side. The Euro front turnsignals drop right into the US bucket although you do need a Euro lens with the clear bottom. Besides an LED-compatible flasher, all other bulbs can be incandescent including the tach indicators. I still run incandescent tach indicators. |
BENBRO02 |
@spoke Can I add front euro with blanking (does this mean the white portion turns off when you activate a directional) and not effect the dash light if I keep incandescent bulbs in the rear? @BENBRO02 In general, converting to LED turnsignals will mess with your flasher relay. Do you have an early (separate L and R indicators) or late (single L/R indicator) tach? In either case, when you change to LED turnsignals, the flasher relay will not behave properly with the tach indicators. You need to swap out the OEM flasher relay with a modified EP26 LED-compatible flasher relay. About the Euro front turnsignals, yes the white LEDs shut off when the turnsignal is active on that side. The Euro front turnsignals drop right into the US bucket although you do need a Euro lens with the clear bottom. Besides an LED-compatible flasher, all other bulbs can be incandescent including the tach indicators. I still run incandescent tach indicators. Thanks for your explanation. I have a late tach |
Rusty |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 7,987 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: South East States ![]() ![]() ![]() |
Just a quick bump and some praise for Spoke and his LED kits. He makes items to order. My package arrived early from his shipping estimate.
I outfitted all of my car (less fog lights) in less than an hour today. Everything was as simple as could be. The improved lighting performance is a huge safety upgrade for our little cars, IMO. Thanks, @spoke! |
Lo-Fi Version | Time is now: 14th September 2025 - 06:05 AM |
