V8 conversion exhaust question, over or under? |
ringerdc |
Jan 15 2015, 11:10 PM
Newbie Group: Members Posts: 11 Joined: 28-January 13 From: Calistoga, Northern California Member No.: 15,443 Region Association: Northern California |
What are the "pros and cons" of routing the exhaust pipes over or under the axles in a V8 setup? I see that most V8 conversions choose the "over" configuration using an "s" pipe. However, the "under" route is more of a straight path. In both the 4 and 6 factory setups the pipes are routed under the axle as well. Hmmmm..
Inquiring minds want to know |
Maltese Falcon |
Jan 17 2015, 03:27 PM
Advanced Member Group: Members Posts: 4,663 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
Here is my old setup. Over the axle. Try to keep Square Joints out of the equation (like at these muffler discharges) Realizing space requirements and sharp turns , square bends =power loss, almost like Press-bending Vs. Mandrel bending. If your muffler shop is building a system for you and does not understand exhaust flow, nor have tight radius bends, I'll be happy to send you some random mandrel bends no cost (you pay shipping). I usually recycle remnants every week, but available if on hand (IMG:style_emoticons/default/welder.gif) Marty |
andys |
Jan 17 2015, 04:07 PM
I went over the axles for most of the reasons many have already stated. Notice the heat shielding. The muffler shields are available from Flowmaster. I get a drone at 2000RPM. Perhaps the next time I drop the motor/trans, I may add Helmholtz chambers to cancel out the drone. Granted a cross-over would reduce some of the noise, but a lack of a tidy solution will probably keep me from doing it. BTW, those Flowmaster's are three chambered, and according to the literature, they greatly reduce interior noise.
Andys Attached thumbnail(s) |
Bruce Hinds |
Jan 17 2015, 04:19 PM
V-8 madness Group: Members Posts: 733 Joined: 27-December 06 From: Port Orchard, WA Member No.: 7,391 Region Association: Pacific Northwest |
I went over the axles for most of the reasons many have already stated. Notice the heat shielding. The muffler shields are available from Flowmaster. I get a drone at 2000RPM. Perhaps the next time I drop the motor/trans, I may add Helmholtz chambers to cancel out the drone. Granted a cross-over would reduce some of the noise, but a lack of a tidy solution will probably keep me from doing it. BTW, those Flowmaster's are three chambered, and according to the literature, they greatly reduce interior noise. Andys Andys - what kind of gearbox is that? |
andys |
Jan 17 2015, 04:21 PM
Mike Bellis |
Jan 17 2015, 05:18 PM
I went over the axles for most of the reasons many have already stated. Notice the heat shielding. The muffler shields are available from Flowmaster. I get a drone at 2000RPM. Perhaps the next time I drop the motor/trans, I may add Helmholtz chambers to cancel out the drone. Granted a cross-over would reduce some of the noise, but a lack of a tidy solution will probably keep me from doing it. BTW, those Flowmaster's are three chambered, and according to the literature, they greatly reduce interior noise. Andys Awesome craftsmanship! (IMG:style_emoticons/default/wub.gif) |
speed metal army |
Jan 17 2015, 08:05 PM
Waiting for the rain to stop... Group: Members Posts: 1,068 Joined: 4-September 10 From: PNW Member No.: 12,137 Region Association: Canada |
bulitt |
Jan 17 2015, 08:45 PM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
I went over the axles for most of the reasons many have already stated. Notice the heat shielding. The muffler shields are available from Flowmaster. I get a drone at 2000RPM. Perhaps the next time I drop the motor/trans, I may add Helmholtz chambers to cancel out the drone. Granted a cross-over would reduce some of the noise, but a lack of a tidy solution will probably keep me from doing it. BTW, those Flowmaster's are three chambered, and according to the literature, they greatly reduce interior noise. Andys Fmasters= drone city. |
andys |
Jan 17 2015, 09:29 PM
I went over the axles for most of the reasons many have already stated. Notice the heat shielding. The muffler shields are available from Flowmaster. I get a drone at 2000RPM. Perhaps the next time I drop the motor/trans, I may add Helmholtz chambers to cancel out the drone. Granted a cross-over would reduce some of the noise, but a lack of a tidy solution will probably keep me from doing it. BTW, those Flowmaster's are three chambered, and according to the literature, they greatly reduce interior noise. Andys Fmasters= drone city. It only drones in about a 200RPM range, so I wouldn't categorize that as "drone city." I can easily drive around it. Any pieced together exhaust has the likelihood for droning, but it can be cancelled out. Production car systems are engineered and developed and tested to avoid/cancel drone. Much of the time, they can design chambers within the muffler that can cancel the drone of a specific engine configuration; one size does not fit all! In my case, knowing the RPM range of the drone, I can now configure a 1/4 wave drone cancelling chamber. To help soften the exhaust note, I can also cut the exhaust tips at an angle, but I don't think I'd like the look in my particular case. Andys |
messix |
Jan 17 2015, 09:39 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
I was just thinking [I know... dangerous] an easy way to build a "anti-drone" exhaust, use 2 1 in 2 out mufflers like these http://www.summitracing.com/parts/mpe-1328...CFVJhfgod6RkAoQ and use one of the outlets on each to use as a cross over where the stock muffler would be.
I would draw up a picture but crayons don't upload |
mgp4591 |
Jan 17 2015, 10:53 PM
914 Guru Group: Members Posts: 5,376 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
I went over the axles for most of the reasons many have already stated. Notice the heat shielding. The muffler shields are available from Flowmaster. I get a drone at 2000RPM. Perhaps the next time I drop the motor/trans, I may add Helmholtz chambers to cancel out the drone. Granted a cross-over would reduce some of the noise, but a lack of a tidy solution will probably keep me from doing it. BTW, those Flowmaster's are three chambered, and according to the literature, they greatly reduce interior noise. Andys I really like this setup- compact and well done. Do you have any sideshots of this or is it in a link for your build? (IMG:style_emoticons/default/smilie_pokal.gif) |
rick 918-S |
Jan 18 2015, 07:51 AM
Hey nice rack! -Celette Group: Members Posts: 20,464 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Under, tuck them in slightly as they pass the axle to clear the axle swing path. Never had an issue with the ground in 10's of thousands of miles. I installed a balance pipe between the mufflers just above the exhaust outlet. Simple. (IMG:style_emoticons/default/assimilate.gif)
v82go |
Jan 18 2015, 08:18 AM
Resident Contrarian Group: Members Posts: 249 Joined: 9-December 04 From: Lakeland, Fl. Member No.: 3,250 |
I too went under on both of mine (one sbc and a LS6),
On my first one I tried the dual flowmasters and grew tired of the drone, after building 3 or 4 more exhaust systems, I ended up with a good sounding Porsche GT3 muffler (ebay), not too loud and no drone. On my LS I have 2 Corvette C5 mufflers, I gutted and shortened and tied together. These have 2 hidden outlets and a exposed center outlet. No drone, but rather loud and rowdy sounding. I have had no issues by going under the axles. Attached image(s) |
Amenson |
Jan 18 2015, 08:24 AM
That's opposite lock!! Group: Members Posts: 645 Joined: 27-May 05 From: Dublin, OH Member No.: 4,154 Region Association: None |
I agree, we must have a sound clip! Cheers, Scott |
bulitt |
Jan 18 2015, 08:52 AM
I went over the axles for most of the reasons many have already stated. Notice the heat shielding. The muffler shields are available from Flowmaster. I get a drone at 2000RPM. Perhaps the next time I drop the motor/trans, I may add Helmholtz chambers to cancel out the drone. Granted a cross-over would reduce some of the noise, but a lack of a tidy solution will probably keep me from doing it. BTW, those Flowmaster's are three chambered, and according to the literature, they greatly reduce interior noise. Andys Fmasters= drone city. It only drones in about a 200RPM range, so I wouldn't categorize that as "drone city." I can easily drive around it. Any pieced together exhaust has the likelihood for droning, but it can be cancelled out. Production car systems are engineered and developed and tested to avoid/cancel drone. Much of the time, they can design chambers within the muffler that can cancel the drone of a specific engine configuration; one size does not fit all! In my case, knowing the RPM range of the drone, I can now configure a 1/4 wave drone cancelling chamber. To help soften the exhaust note, I can also cut the exhaust tips at an angle, but I don't think I'd like the look in my particular case. Andys Had them on a pickup. It was unbearable. |
andys |
Jan 18 2015, 11:42 AM
[quote name='mgp4591' date='Jan 17 2015, 08:53 PM' post='2135435']
Andys [/quote] I really like this setup- compact and well done. Do you have any sideshots of this or is it in a link for your build? (IMG:style_emoticons/default/smilie_pokal.gif) [/quote] Here's a link to my retrospective build thread. If you don't see what you're looking for, let me know. http://www.914world.com/bbs2/index.php?sho...4625&hl=ls1 retrospective Andys |
BIGKAT_83 |
Jan 18 2015, 12:01 PM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
I'm running Magnaflow glasspacks under the axle and have no problem with drone. These are great mufflers I had them on a new mustang and when I sold the car I replaced them with the stock mufflers. I think the stock ones were louder
I tried some Flowmasters 40's Used them for less than 1 mile. Way to loud. Bob (IMG:style_emoticons/default/shades.gif) |
speed metal army |
Jan 18 2015, 01:09 PM
I'm running Magnaflow glasspacks under the axle and have no problem with drone. These are great mufflers I had them on a new mustang and when I sold the car I replaced them with the stock mufflers. I think the stock ones were louder I tried some Flowmasters 40's Used them for less than 1 mile. Way to loud. Bob (IMG:style_emoticons/default/shades.gif) +1 on Magnaflow. Best sounding, least drone. |
andys |
Jan 18 2015, 01:13 PM
I'm running Magnaflow glasspacks under the axle and have no problem with drone. These are great mufflers I had them on a new mustang and when I sold the car I replaced them with the stock mufflers. I think the stock ones were louder I tried some Flowmasters 40's Used them for less than 1 mile. Way to loud. Bob (IMG:style_emoticons/default/shades.gif) Bob, Mine are Flowmaster 50's. According to their literature (interior/exterior db charts), they're a lot quieter than the 40's. Just FYI. Andys |
BIGKAT_83 |
Jan 18 2015, 01:19 PM
I kinda figured yours were 50's they look a little longer.
Bob |
Lo-Fi Version | Time is now: 23rd May 2024 - 06:52 AM |
