FS 914 1970 with 24k miles |
fear |
Jan 20 2015, 12:56 PM
Newbie Group: Members Posts: 2 Joined: 20-January 15 From: Minden NV Member No.: 18,341 Region Association: Northern California |
This is a collectors grade Porsche 914. It has 24k on the odometer and it is documented with all the paperwork ever. I am the second owner and have put less than 500 miles on it in 2 years. The car is Original had a few things done by the first owner but nothing major. was completely rebuilt in the late 80s(Documented). It has the original 1.7L engine and transmission. Has been valued at the price.
I will sell internationally. And will deliver for additional costs from Utah west. I can also meet you halfway or the likes. If you want a solid investment I highly recommend this car. Please Email me with you phone number and I will get back to you ASAP |
914runnow |
Aug 30 2015, 08:25 AM
Member Group: Members Posts: 340 Joined: 19-April 04 From: Modesto California Member No.: 1,948 Region Association: None |
off at 1pm to see this car..pretty excited....
914runnow |
Aug 31 2015, 09:41 AM
The car was fully repainted to the red from green....It is a 1971...The carpet was also replaced thru out...dash is cracked...but the 71 interior ..all n all looks good..
as far as seats and vinyl...the mirror and visors and shift knob have been replaced.. the horn ring shows very well...appears as to be very low miles..windows roll up n down nice..the wood dash face is a good job...looks kool..but NOT oem..speaker grills have some broken vanes....fuse panel cover missing..the door stays need the rebuild kits...needs new seals for all of interior top areas.. ODO is at 25 thou now..did not check behind the seats for rust...front trunk is solid..with the spare as original and whitewall tire..tools are all there..but have surface rust...tank and related surfaces are nice for a low mile car..although the plated surfaces in some areas should be brighter for the miles..the brake resv strap is black and that is flaking.. Rear trunk has had some repair as far as rust and still has a few holes in rear corner of psngr side....original jack is still there..as the front and interior..the carpet pcs also replaced..the rear t top rubber holder need to be replaced..cups and front holders good..the top of the rear tail hsngs have the small heat crack on the tops... the front valance is missing..and the grill covers in the bumper are missing some vanes..there is repair needed for the front bumper...the front lenses are decent.. did not pull the lenses and inspect the chrome inside..psngr side clearance light assy needs repair and lens replaced..drvr is good although lens is faded.. windshield chrome is nice..T-top is REALLY nice on the exterior..wow really nice.. the rubber tops on the bumpers are okay.....and the vinyl was installed on the targa bar..this was not oem on this car...rear lenses are good..and the rear valance and outer rockers have all been restored/reworked... drvr hell hole good..psngr unknown..batt tray looked good ..AND the recall battery top cover was on there..way koool!! Motor is a mystery..as many parts are repainted..although....the heat xchngrz for stock look XLNT!! even gray oem paint on the heat tubes.. and heat boxes look xlnt.. Bursch 1.7 muff....replaced oem springs and Boge shocks on rear ..sits up nice.. Sooooooo before I run out of battery...nice car needs TLC...low mile?? Many parts and pcs point to that direction..owner says he has the docs to prove..as far as a Concour car??no..still if a low mile car with what has been done...not bad..still body repairs are needed...and pcs replaced..71's are getting hard to find ..so I recommend to see it in person..and go from there.. Thanx Rx |
Lo-Fi Version | Time is now: 16th May 2024 - 08:47 PM |
