Just got 1972 914 where do I start |
Joe penge |
Jan 20 2015, 04:09 PM
Newbie Group: Members Posts: 23 Joined: 20-January 15 From: Illinois Chicago northern suburb Member No.: 18,342 Region Association: Upper MidWest |
New here but just picked up my first 914 it's a 1972 most original has not ran in 15 years most most kept in barn needs lots of work but where do I start?i put battery in and found that all gas lines rope braided are all leaking old fuel pump under car is bad put some Either down carb and gas pump inline to test start get thing it did start just don't stay running and kills soon as I hit gas pedal...need idea what to do first or where to start and do I try to find origanal parts?any info is good or ideas to what most of you did?
--axel-- |
Jan 20 2015, 04:17 PM
Newbie Group: Members Posts: 39 Joined: 12-April 04 From: Lenexa, KS Member No.: 1,920 Region Association: None |
New here but just picked up my first 914 it's a 1972 most original has not ran in 15 years most most kept in barn needs lots of work but where do I start?i put battery in and found that all gas lines rope braided are all leaking old fuel pump under car is bad put some Either down carb and gas pump inline to test start get thing it did start just don't stay running and kills soon as I hit gas pedal...need idea what to do first or where to start and do I try to find origanal parts?any info is good or ideas to what most of you did? Obviously, don't try to run it with leaking fuel lines. Too many of these have been lost to fire. Most of us have replaced the fuel lines with stainless steel ones made by Tangerine Racing or similar. It is likely that the fuel tank strainer has been gummed up. There is a strainer sock inside the fuel tank that should be checked/replaced. Fuel injectors are probably not functioning properly, and should be cleaned. Test fuel pump. Most people get their parts from Pelican Parts. I know GPR is trying to establish a place in the market also. General consensus is to stay away from Auto Atlanta. So many more items, but this should get you started on the fuel side. |
Lo-Fi Version | Time is now: 13th May 2024 - 04:15 AM |
