Just got 1972 914 where do I start |
Joe penge |
Jan 20 2015, 04:09 PM
Newbie Group: Members Posts: 23 Joined: 20-January 15 From: Illinois Chicago northern suburb Member No.: 18,342 Region Association: Upper MidWest |
New here but just picked up my first 914 it's a 1972 most original has not ran in 15 years most most kept in barn needs lots of work but where do I start?i put battery in and found that all gas lines rope braided are all leaking old fuel pump under car is bad put some Either down carb and gas pump inline to test start get thing it did start just don't stay running and kills soon as I hit gas pedal...need idea what to do first or where to start and do I try to find origanal parts?any info is good or ideas to what most of you did?
Erben914 |
Jan 20 2015, 11:40 PM
Member Group: Members Posts: 137 Joined: 1-January 13 From: Sacramento Member No.: 15,314 Region Association: Central California |
:wttc
If you have some patience, tools and common sense you are well on your way to getting it on the road. I would check the longs and he'll hole for structural rust before you get to far I to it tho. Here is some light ivory inspiration for you. (IMG:style_emoticons/default/biggrin.gif) |
Joe penge |
Jan 21 2015, 10:12 AM
:wttc If you have some patience, tools and common sense you are well on your way to getting it on the road. I would check the longs and he'll hole for structural rust before you get to far I to it tho. Here is some light ivory inspiration for you. (IMG:style_emoticons/default/biggrin.gif) Are you relocating your full pump or keeping it the oem unit same spot under rear car below the battery ?? I found oem pump $240 with the three ports |
Lo-Fi Version | Time is now: 12th May 2024 - 01:39 PM |
