Just got 1972 914 where do I start |
Joe penge |
Jan 20 2015, 04:09 PM
Newbie Group: Members Posts: 23 Joined: 20-January 15 From: Illinois Chicago northern suburb Member No.: 18,342 Region Association: Upper MidWest |
New here but just picked up my first 914 it's a 1972 most original has not ran in 15 years most most kept in barn needs lots of work but where do I start?i put battery in and found that all gas lines rope braided are all leaking old fuel pump under car is bad put some Either down carb and gas pump inline to test start get thing it did start just don't stay running and kills soon as I hit gas pedal...need idea what to do first or where to start and do I try to find origanal parts?any info is good or ideas to what most of you did?
Dave_Darling |
Jan 24 2015, 09:09 PM
914 Idiot Group: Members Posts: 14,984 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
If the injectors are leaking from the fuel lines, they're pretty easy. If the lines to the injectors still have the old crimp-on clamps, you'll have to cut them off. Replace with fuel injector hose clamps--the ones shapes like an omega or horseshoe, not the ones with a worm gear that cut into the hose.
If an injectors is leaking around the electrical connector, or down right where it plugs into the intake, you should replace the whole injector. Injectors are held into the intake pipes by one M6 (10mm wrench) nut. Remove that nut, pull the metal retainer off the stud on the intake, grab the injector and pull straight out. There is one large O-ring on the injector body that the retainer seats on. There is one small O-ring near the end of the injector, where it slides into the intake. Replace both of those O-rings; leaks in the latter especially make for some ugly driveability problems. --DD |
Lo-Fi Version | Time is now: 12th May 2024 - 09:09 PM |
