> Cockpit substructure, Thinking about drilling a hole through it
Randal
post Jan 22 2015, 10:00 AM
Thinking about drilling a 3/4 inch hole through the firewall to an Accusump on the other side. The Accusump will sit facing backwards towards the cockpit firewall mounted where the seat normally goes.
Anyone ever drilled through this section.
There is a black arrow where I want the hole.
All advice appreciated.
BTW I'm going to cover up that higher hole where the lines used to run to the front cooler.
ChrisFoley
post Jan 22 2015, 10:22 AM
I am Tangerine Racing
You can put a bulkhead fitting through the pocket there.
That's the only location on the lower firewall where the two panels have no empty space between them.
Rob-O
post Jan 22 2015, 10:55 AM
What Chris said. The center of that dimple matches a dimple on the interior of the vehicle. Any other spot on the lower firewall and you have to go through two pieces of metal spaced 2.5 or so inches apart.
Steve
post Jan 22 2015, 12:11 PM
I drilled a 3/4" hole in that dimple to run the DME harness for my 3.2 motor. No issues. Plenty of room on the other side, since it's low on the firewall behind the passenger seat.
McMark
post Jan 22 2015, 12:13 PM
914 Freak!
To expand on what Chris said, that area is a boxes section. So where the arrow is you would have to drill through one layer of sheet metal, and then drop into the box and drill through the next layer into the cabin.
If you drill though the dimple, those two layers of metal are back to back. But there a spot welds in the dimple. I imagine this was done for structure to tie those pieces together. If you remove the spot welds and don't compensate for it (weld around the circumference of your drilled hole) you're taking that structure away. It's probably not going to affect a caged car like yours all that much, but I'm not a big fan of it.
If I were doing it here, I would drill through the box section, then weld in a tube to make a sealed hole in the body. Then feed AN line through the hole and add the ends on after.
Randal
post Jan 22 2015, 12:19 PM
QUOTE(Rob-O @ Jan 22 2015, 08:55 AM) *
Ahhh, now I see it. Just move the Accusump over to the right, drill a hole, install a bulkhead fitting and I'm good to go. So much easier and less costly than running the lines through the old hole.
Man, the stuff we go through for better weight distribution!
Thanks for the advice all!
Randal
QUOTE(Racer Chris @ Jan 22 2015, 08:22 AM) *
Thank you Sir!
post Jan 22 2015, 12:22 PM
Resident German
QUOTE(McMark @ Jan 22 2015, 10:13 AM) *
Like so:
(IMG:http://www.914world.com/bbs2/uploads/post-179-1151215319.jpg)
(IMG:http://www.914world.com/bbs2/uploads/post-179-1175805981.jpg)
(IMG:http://www.914world.com/bbs2/uploads/post-179-1175806021.jpg)
(IMG:http://www.914world.com/bbs2/uploads/post-179-1175806054.jpg)
(IMG:http://www.914world.com/bbs2/uploads/post-179-1175806091.jpg)
(IMG:http://www.914world.com/bbs2/uploads/post-179-1176965977.jpg)
(IMG:http://www.914world.com/bbs2/uploads/post-179-1177645190.jpg)
(IMG:http://www.914world.com/bbs2/uploads/post-179-1182813892.jpg)
Kansas 914
post Jan 22 2015, 12:54 PM
QUOTE(SirAndy @ Jan 22 2015, 11:22 AM) *
Like so:
Nicely done!
JRust
post Jan 22 2015, 06:03 PM
(IMG:style_emoticons/default/agree.gif) That's is effective & looks good. Nice mod Andy (IMG:style_emoticons/default/first.gif)
Randal
post Jan 22 2015, 06:21 PM
QUOTE(SirAndy @ Jan 22 2015, 10:22 AM) *
Like so:
Nice work Andy.
What is that blue line called? Looks like it just slips on to the fittings.
ChrisFoley
post Jan 22 2015, 07:28 PM
Aeroquip AQP Socketless Hose
post Jan 22 2015, 08:17 PM
Resident German
QUOTE(Randal @ Jan 22 2015, 04:21 PM) *
I got the hose and fittings from Pegasus Racing.
Operating range: Up to 250 psi, 300 deg. F
Burst pressure: 1000 psi
Randal
post Jan 22 2015, 10:21 PM
QUOTE(Racer Chris @ Jan 22 2015, 05:28 PM) *
Sure looks like a lot easier to work with as compared to the SS wrapped lines. Decided to go that way, but the pliers to crimp the clamps, recommended in high temperature situations, was $80 bucks. Ouch.
Oh well another interesting tool to place in the green felt.
post Jan 22 2015, 10:40 PM
Resident German
QUOTE(Randal @ Jan 22 2015, 08:21 PM) *
I've been running this setup without clamps for years now, never had a problem.
Randal
post Jan 22 2015, 10:56 PM
QUOTE(SirAndy @ Jan 22 2015, 08:40 PM) *
Well you know where to borrow the special pliers now. (IMG:style_emoticons/default/biggrin.gif)
Mark Henry
post Jan 22 2015, 11:13 PM
that's what I do!
QUOTE(SirAndy @ Jan 22 2015, 09:17 PM) *
Isn't that Parker Pushlok hose?
Randal
post Jan 23 2015, 06:58 PM
QUOTE(Mark Henry @ Jan 22 2015, 09:13 PM) *
As per Foley, "Aeroquip AQP Socketless Hose"
I don't think it's the same, but maybe. I'll have to call the Parker guys in San Jose and find out.
post Jan 23 2015, 07:28 PM
Resident German
The Parker Pushlok is very similar:
http://www.914world.com/uploads/4281_b1.pdf
- Lo-Fi Version Time is now: 7th December 2025 - 10:08 AM
