Front trunk springs length open & closed, Close assist gas spring upgrade |
Harpo |
Jan 23 2015, 08:18 AM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
I would like to replace my front trunk springs with gas shocks. The problem is most gas shocks the relaxed state is open. However to replace the spring with out changing the design requires a gas shock that is closed in the relaxed state
This is where I need some help from my fellow 914world members I need the measurements of the spring on the car with the hood open & closed. The delta of these will allow me to order the right spring. My car is in pieces and getting ready for paint Thanks David |
Harpo |
Jan 24 2015, 02:35 PM
There is 2.5 inches of travel with the factory spring. The close assist gas spring below is good for 30 lbs so two of them ought to be appropriate for the front trunk hood.
Mike Bellis |
Jan 24 2015, 03:31 PM
There is 2.5 inches of travel with the factory spring. The close assist gas spring below is good for 30 lbs so two of them ought to be appropriate for the front trunk hood. Kind of pricey! http://www.mcmaster.com/#close-assist-gas-springs/=vlyv9r |
Lo-Fi Version | Time is now: 15th May 2024 - 04:50 AM |
