Exhaust stud woes, What's the next step? |
saigon71 |
Jan 24 2015, 11:39 AM
Senior Member Group: Members Posts: 1,998 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
Nothing is ever easy on these cars...
My heat exhangers got some oil in them from the bad oil cooler seals, so I decided to pull them for a good cleaning. One exhaust nut was really difficult to remove. Once I finally got it off, I saw that the threads were galled. Ordered some new exhaust studs. Went to work removing the old one after researching 914 world. Heated stud boss with MAP torch & sprayed a bunch of PB blaster. Welded a nut on the end...nut kept breaking loose without budging the stud, removing small portions off the top of the stud during the six attempts. Then welded a bar to the remainder of the stud and used an adjustable wrench for leverage. Heat & PB Blaster, working it a little at a time, back & forth. It finally broke free. Reheat & apply more PB. On about the 5th cycle, the stud broke off below the level of the head. Engine is in the car & I'd like to keep it that way. What are my best options for getting this thing out now...and installing a new stud? I've had horrible luck with EZ-outs on other applications. Thanks! |
913B |
Oct 2 2015, 02:43 PM
Senior Member Group: Members Posts: 847 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
Dang you the MAN, I like your persistence and not give up.
I am subscribing to this thread for future reference. BTW, how thick was that drill jig have to be ? Drill bits, was there special drill bits you use/recommend for this job ? I take it harbor freight ones would NOT do. Great job ! (IMG:style_emoticons/default/first.gif) (IMG:style_emoticons/default/first.gif) (IMG:style_emoticons/default/first.gif) Ted |
saigon71 |
Oct 3 2015, 04:22 PM
Dang you the MAN, I like your persistence and not give up. I am subscribing to this thread for future reference. BTW, how thick was that drill jig have to be ? Drill bits, was there special drill bits you use/recommend for this job ? I take it harbor freight ones would NOT do. Great job ! (IMG:style_emoticons/default/first.gif) (IMG:style_emoticons/default/first.gif) (IMG:style_emoticons/default/first.gif) Ted Thanks Ted. Necessity is the mother of invention. (IMG:style_emoticons/default/dry.gif) My drill jigs are about 3/8" thick. I used a set of Dewalt pilot point drill bits (set was about $20), purchased at Lowes and plenty of lube. |
Lo-Fi Version | Time is now: 17th May 2024 - 05:51 PM |
