Exhaust stud woes, What's the next step? |
saigon71 |
Jan 24 2015, 11:39 AM
Senior Member Group: Members Posts: 1,998 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
Nothing is ever easy on these cars...
My heat exhangers got some oil in them from the bad oil cooler seals, so I decided to pull them for a good cleaning. One exhaust nut was really difficult to remove. Once I finally got it off, I saw that the threads were galled. Ordered some new exhaust studs. Went to work removing the old one after researching 914 world. Heated stud boss with MAP torch & sprayed a bunch of PB blaster. Welded a nut on the end...nut kept breaking loose without budging the stud, removing small portions off the top of the stud during the six attempts. Then welded a bar to the remainder of the stud and used an adjustable wrench for leverage. Heat & PB Blaster, working it a little at a time, back & forth. It finally broke free. Reheat & apply more PB. On about the 5th cycle, the stud broke off below the level of the head. Engine is in the car & I'd like to keep it that way. What are my best options for getting this thing out now...and installing a new stud? I've had horrible luck with EZ-outs on other applications. Thanks! |
veekry9 |
Jan 24 2015, 01:25 PM
OldMember Group: Retired Members Posts: 3,068 Joined: 17-June 13 From: TO Member No.: 16,025 Region Association: Canada |
Nothing is ever easy on these cars... ....It finally broke free. Reheat & apply more PB. On about the 5th cycle, the stud broke off below the level of the head. Engine is in the car & I'd like to keep it that way. What are my best options for getting this thing out now...and installing a new stud? I've had horrible luck with EZ-outs on other applications. Thanks! PITA.Huh? The heat +PB broke through the corrosion and now needs more of the same. A hi-speed grinder to drill thru the bolt's minor dia (6mm)and removal of the thds helix. Underneath the car on your back with a face mask,in close quarters. Start drilling on center with a small dia drill(5/32 .094)use a center punch,carefully. Continue drilling with ever larger drills until the minor dia is reached.Do Not drill out the head's thds. Cleanout hole + remaining thds with brakeclean and insert new stud with Red Loctite or hitemp epoxy. Tough work,good luck. (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 2nd May 2024 - 10:38 PM |
