Exhaust stud woes, What's the next step? |
saigon71 |
Jan 24 2015, 11:39 AM
Senior Member Group: Members Posts: 1,998 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
Nothing is ever easy on these cars...
My heat exhangers got some oil in them from the bad oil cooler seals, so I decided to pull them for a good cleaning. One exhaust nut was really difficult to remove. Once I finally got it off, I saw that the threads were galled. Ordered some new exhaust studs. Went to work removing the old one after researching 914 world. Heated stud boss with MAP torch & sprayed a bunch of PB blaster. Welded a nut on the end...nut kept breaking loose without budging the stud, removing small portions off the top of the stud during the six attempts. Then welded a bar to the remainder of the stud and used an adjustable wrench for leverage. Heat & PB Blaster, working it a little at a time, back & forth. It finally broke free. Reheat & apply more PB. On about the 5th cycle, the stud broke off below the level of the head. Engine is in the car & I'd like to keep it that way. What are my best options for getting this thing out now...and installing a new stud? I've had horrible luck with EZ-outs on other applications. Thanks! |
relentless |
Jan 29 2015, 04:05 PM
Member Group: Members Posts: 350 Joined: 1-April 07 From: Oregon Member No.: 7,636 |
The stud is broken off below the level of the head, so good luck grinding that flat.
If you can find a piece of tubing the exact OD of the hole you can center a punch that just fits the ID, but good luck finding one with those specs. You might be able to have a machine shop machine a piece of old stud with a perfectly centered hole, and if you could get that held perfectly aligned you *might* be able to drill it out. I've used that technique before but always used a stud extraction device. I'm surprised you didn't try the 50-50 acetone/ATF mix, as it works better than any penetrating fluid you can purchase. I sometimes soak fasteners for a week or two before I even try to extract them, and of course heat is your friend. Good luck! |
Lo-Fi Version | Time is now: 2nd May 2024 - 11:37 PM |
