Exhaust stud woes, What's the next step? |
saigon71 |
Jan 24 2015, 11:39 AM
Senior Member Group: Members Posts: 1,998 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
Nothing is ever easy on these cars...
My heat exhangers got some oil in them from the bad oil cooler seals, so I decided to pull them for a good cleaning. One exhaust nut was really difficult to remove. Once I finally got it off, I saw that the threads were galled. Ordered some new exhaust studs. Went to work removing the old one after researching 914 world. Heated stud boss with MAP torch & sprayed a bunch of PB blaster. Welded a nut on the end...nut kept breaking loose without budging the stud, removing small portions off the top of the stud during the six attempts. Then welded a bar to the remainder of the stud and used an adjustable wrench for leverage. Heat & PB Blaster, working it a little at a time, back & forth. It finally broke free. Reheat & apply more PB. On about the 5th cycle, the stud broke off below the level of the head. Engine is in the car & I'd like to keep it that way. What are my best options for getting this thing out now...and installing a new stud? I've had horrible luck with EZ-outs on other applications. Thanks! |
IronHillRestorations |
Jan 29 2015, 09:48 PM
I. I. R. C. Group: Members Posts: 6,716 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I didn't mean to sound insulting Saigon, I just don't want you to get deeper in a hole.
From the closing the door after the cows are out department: A vintage piece of equipment that really works good for stuck studs, is a carbon arc torch that you use with an arc welder. You can contact that on the studs and get it red hot in seconds without the ancillary heat on everything else. |
stugray |
Jan 30 2015, 12:05 AM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
A vintage piece of equipment that really works good for stuck studs, is a carbon arc torch that you use with an arc welder. You can contact that on the studs and get it red hot in seconds without the ancillary heat on everything else. I have a resistance welder that is basically a transformer in a box with a handle. It has the carbon arc rod. We used to use it for soldering really big stuff. I never thought of using it for that. I guess it would work well on gears and such as well. |
Lo-Fi Version | Time is now: 3rd May 2024 - 05:14 AM |
