Exhaust stud woes, What's the next step? |
saigon71 |
Jan 24 2015, 11:39 AM
Senior Member Group: Members Posts: 1,998 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
Nothing is ever easy on these cars...
My heat exhangers got some oil in them from the bad oil cooler seals, so I decided to pull them for a good cleaning. One exhaust nut was really difficult to remove. Once I finally got it off, I saw that the threads were galled. Ordered some new exhaust studs. Went to work removing the old one after researching 914 world. Heated stud boss with MAP torch & sprayed a bunch of PB blaster. Welded a nut on the end...nut kept breaking loose without budging the stud, removing small portions off the top of the stud during the six attempts. Then welded a bar to the remainder of the stud and used an adjustable wrench for leverage. Heat & PB Blaster, working it a little at a time, back & forth. It finally broke free. Reheat & apply more PB. On about the 5th cycle, the stud broke off below the level of the head. Engine is in the car & I'd like to keep it that way. What are my best options for getting this thing out now...and installing a new stud? I've had horrible luck with EZ-outs on other applications. Thanks! |
saigon71 |
Jan 31 2015, 05:31 PM
Made three different fixtures so I could step drill the stud. My new exhaust studs came in, so I added the length of the stud threads to the thickness of the jig and marked the drill bit with tape:
Time to drill. Used a fine point red sharpie to mark the center punch hole in the stud, so I could see it through the pilot hole and tightened it down. Drilled right down the center. Aligned the next two jigs with the previous drill size and hole: |
Lo-Fi Version | Time is now: 3rd May 2024 - 05:31 AM |
