Went to fix Minor Oil Leaks on Taco Plate, Not Expecting this |
914Sixer |
Jan 24 2015, 08:07 PM
I knew I had problems at the taco plate because it was really leaking there. Lots of grime and oil. I suspected a bad o ring, missing bolt crush washer or some one left the paper gasket off. Started to clean off the area when I found lots of RTV under the dirt. I started peeling back the layers and found 1/4 of the case ring was missing. (IMG:style_emoticons/default/WTF.gif) No damage anywhere to the rest of the case or the motor bar. I am lost as to how this got damaged. The only thing that comes to mind is a floor jack. I guess I will be looking for a new case and doing an overhaul. I just love DAPO's.
Attached image(s) |
eeyore |
Jan 24 2015, 10:25 PM
Senior Member Group: Members Posts: 889 Joined: 8-January 04 From: meridian, id Member No.: 1,533 Region Association: None |
I had a similar problem, just not as big.
I machined a 1/4" thick piece of aluminum with a groove around the outer edge to hold a big o-ring and a small countersunk area around each bolt hole for small o-rings. It held good. I could draw up dimensions for another. It isn't a complicated thing to machine. I'd pay $100 to have another duplicated if it helped me avoid a rebuild. Here is a picture of my nylon prototype . |
Lo-Fi Version | Time is now: 17th May 2024 - 04:08 AM |
