Went to fix Minor Oil Leaks on Taco Plate, Not Expecting this |
914Sixer |
Jan 24 2015, 08:07 PM
I knew I had problems at the taco plate because it was really leaking there. Lots of grime and oil. I suspected a bad o ring, missing bolt crush washer or some one left the paper gasket off. Started to clean off the area when I found lots of RTV under the dirt. I started peeling back the layers and found 1/4 of the case ring was missing. (IMG:style_emoticons/default/WTF.gif) No damage anywhere to the rest of the case or the motor bar. I am lost as to how this got damaged. The only thing that comes to mind is a floor jack. I guess I will be looking for a new case and doing an overhaul. I just love DAPO's.
Attached image(s) |
ChrisFoley |
Jan 25 2015, 09:38 AM
I am Tangerine Racing Group: Members Posts: 7,926 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I've fixed that before - in my shop.
Not in service, only with the case disassembled, although it would be "possible" without doing a teardown. A good welder can build up the aluminum so the seal bore can be recut in a Bridgeport. |
type2man |
Jan 25 2015, 12:11 PM
Member Group: Members Posts: 353 Joined: 3-March 09 From: Miami, Fl Member No.: 10,127 Region Association: South East States |
Wait overnight until all the oil is drained, put the strainer back on with the O-ring and then dab the area with Hondabond(google it). It will seal the area just fine. I had a case where the drain bolt was over tightened and the through bolt was stripped. I put the bolt back through with hondabond and tightened the drain plug and this was 10 years ago. Not one drop of oil on the ground since the repair. JB weld sucks!
rick 918-S |
Jan 25 2015, 12:40 PM
Hey nice rack! -Celette Group: Members Posts: 20,462 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Wait overnight until all the oil is drained, put the strainer back on with the O-ring and then dab the area with Hondabond(google it). It will seal the area just fine. I had a case where the drain bolt was over tightened and the through bolt was stripped. I put the bolt back through with hondabond and tightened the drain plug and this was 10 years ago. Not one drop of oil on the ground since the repair. JB weld sucks! Same principle. I use Yamabond 4 I think. I sealed an active pressure fed oil leak on my 928 engine between the block without pulling the head. Clean, clean, clean, reinstall the cover, apply the Yamabond, let it set over night. Save you from pulling the engine and splitting the case, welding and machining. |
Lo-Fi Version | Time is now: 19th May 2024 - 01:27 AM |
