Went to fix Minor Oil Leaks on Taco Plate, Not Expecting this |
914Sixer |
Jan 24 2015, 08:07 PM
I knew I had problems at the taco plate because it was really leaking there. Lots of grime and oil. I suspected a bad o ring, missing bolt crush washer or some one left the paper gasket off. Started to clean off the area when I found lots of RTV under the dirt. I started peeling back the layers and found 1/4 of the case ring was missing. (IMG:style_emoticons/default/WTF.gif) No damage anywhere to the rest of the case or the motor bar. I am lost as to how this got damaged. The only thing that comes to mind is a floor jack. I guess I will be looking for a new case and doing an overhaul. I just love DAPO's.
Attached image(s) |
914Sixer |
Jan 25 2015, 07:26 PM
I got the car this way from previous owner. I am just now getting around to the underside stuff and getting ready to pull the rockers. I was just planning to put new lower gaskets, new tube o rings and valve covers.
Lo-Fi Version | Time is now: 18th May 2024 - 06:29 PM |
