Went to fix Minor Oil Leaks on Taco Plate, Not Expecting this |
914Sixer |
Jan 24 2015, 08:07 PM
914 Guru Group: Members Posts: 8,882 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I knew I had problems at the taco plate because it was really leaking there. Lots of grime and oil. I suspected a bad o ring, missing bolt crush washer or some one left the paper gasket off. Started to clean off the area when I found lots of RTV under the dirt. I started peeling back the layers and found 1/4 of the case ring was missing. (IMG:style_emoticons/default/WTF.gif) No damage anywhere to the rest of the case or the motor bar. I am lost as to how this got damaged. The only thing that comes to mind is a floor jack. I guess I will be looking for a new case and doing an overhaul. I just love DAPO's.
Attached image(s) |
mikedsilva |
Jul 3 2015, 04:52 AM
Member Group: Members Posts: 90 Joined: 23-February 15 From: Australia Member No.: 18,462 Region Association: Australia and New Zealand |
so glad i found this thread... i have the same problem.
How did you go about fixing it? I am getting an aluminium plate laser cut. Then I plan to clean the area perfectly and use yamabond or similar.. bolt it in and hopefully never need to do anything else... My engine is on a stand so I can turn it upside down... Curious to find out if you repaired or replaced? |
Lo-Fi Version | Time is now: 17th May 2024 - 03:26 AM |
