Went to fix Minor Oil Leaks on Taco Plate, Not Expecting this |
914Sixer |
Jan 24 2015, 08:07 PM
I knew I had problems at the taco plate because it was really leaking there. Lots of grime and oil. I suspected a bad o ring, missing bolt crush washer or some one left the paper gasket off. Started to clean off the area when I found lots of RTV under the dirt. I started peeling back the layers and found 1/4 of the case ring was missing. (IMG:style_emoticons/default/WTF.gif) No damage anywhere to the rest of the case or the motor bar. I am lost as to how this got damaged. The only thing that comes to mind is a floor jack. I guess I will be looking for a new case and doing an overhaul. I just love DAPO's.
Attached image(s) |
stugray |
Jul 4 2015, 11:12 AM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
My first guess would be to have a new aluminum lip machined.
It would look just like the ring on a Ball-Jar lid. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.fantes.com-10819-1436029956.1.jpg) Then JB weld that into position and suck it down with the tacto plate till it cures. Then disassemble and add gaskets/RTV. |
Lo-Fi Version | Time is now: 17th May 2024 - 03:40 AM |
