Went to fix Minor Oil Leaks on Taco Plate, Not Expecting this |
914Sixer |
Jan 24 2015, 08:07 PM
I knew I had problems at the taco plate because it was really leaking there. Lots of grime and oil. I suspected a bad o ring, missing bolt crush washer or some one left the paper gasket off. Started to clean off the area when I found lots of RTV under the dirt. I started peeling back the layers and found 1/4 of the case ring was missing. (IMG:style_emoticons/default/WTF.gif) No damage anywhere to the rest of the case or the motor bar. I am lost as to how this got damaged. The only thing that comes to mind is a floor jack. I guess I will be looking for a new case and doing an overhaul. I just love DAPO's.
Spoke |
Jul 4 2015, 08:14 AM
arkitect |
Jul 4 2015, 08:48 AM
Senior Member Group: Members Posts: 617 Joined: 3-March 10 From: Stockton, CA Member No.: 11,426 Region Association: None |
I'd like to see picts from someone, who has made a case repair and their method.
Dave |
stugray |
Jul 4 2015, 11:12 AM
My first guess would be to have a new aluminum lip machined.
It would look just like the ring on a Ball-Jar lid. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.fantes.com-10819-1436029956.1.jpg) Then JB weld that into position and suck it down with the tacto plate till it cures. Then disassemble and add gaskets/RTV. |
mikedsilva |
Jul 6 2015, 04:49 AM
Member Group: Members Posts: 90 Joined: 23-February 15 From: Australia Member No.: 18,462 Region Association: Australia and New Zealand |
I have the same issue with my car. The plan is to have a aluminium plate cut out, and then to use case sealant to provide a more permanent seal. With that in mind, what product would anyone suggest to use?
I figured that I should still build up the lip, so I cleaned and cleaned and cleaned! So far, it looks as if all the grease is out.. then I put a jar lid on the inside, and used masking tape on the outside. This created a "moat" which I filled with JB weld... Once set, it was filed and shaped to similar shape of the case. It looks as if I might still be able to use the normal, o-ring and taco plate cover.. but if there is a chance of leaking again, I don't see the point. Any comments as to the method I'm planning?? Mike. (IMG:http://www.914world.com/bbs2/uploads_offsite/i1260.photobucket.com-18462-1436179759.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1260.photobucket.com-18462-1436179759.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1260.photobucket.com-18462-1436179759.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1260.photobucket.com-18462-1436179760.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1260.photobucket.com-18462-1436179760.5.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1260.photobucket.com-18462-1436179760.6.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1260.photobucket.com-18462-1436179760.7.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i1260.photobucket.com-18462-1436179761.8.jpg) |
02loftsmoor |
Jul 6 2015, 06:00 AM
Senior Member Group: Members Posts: 577 Joined: 26-June 11 From: Ft. Worth TX Member No.: 13,243 Region Association: Southwest Region |
I'm truck mechanic . We use this stuff called Bellzona, not sure of the spelling, very expensive, to repair engine blocks where the block was damaged it is machineable when cured.
Porschef |
Jul 7 2015, 05:48 AM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
How about MarineTex?
mikedsilva |
Jul 16 2015, 05:37 PM
I had some 5mm aluminium plates, laser cut to replace my taco plate cover...
(IMG:http://www.914world.com/bbs2/uploads_offsite/i1260.photobucket.com-18462-1437089874.1.jpg) The plan is to use case sealant to provide a more permanent seal. I don't have a temp gauge... With just a very light filing around the perimeter of the plate, it is a perfect dropin fit and the bolt holes line up perfectly. Hope it works! (IMG:http://www.914world.com/bbs2/uploads_offsite/i1260.photobucket.com-18462-1437089874.2.jpg) |
mr914 |
Jul 16 2015, 10:06 PM
914 Hillbilly Group: Members Posts: 576 Joined: 11-January 03 From: Lincoln NE Member No.: 131 Region Association: None |
I personally use Devcon F
Aluminum based 2 part putty. Has same thermo expansion rates as aluminum, so with the shrinking and expanding of aluminum it won't eventually crack and separate. Without pulling the motor, I agree with the MOAT approach and sealer. My vote is caused by misplaced floor jack while lifting |
mr914 |
Jul 16 2015, 10:07 PM
Aluminum based 2 part putty. Has same thermo expansion rates as aluminum, so with the shrinking and expanding of aluminum it won't eventually crack and separate. Without pulling the motor, I agree with the MOAT approach and sealer. My vote is caused by misplaced floor jack while lifting (IMG:style_emoticons/default/hissyfit.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 04:08 AM |
