3rd brake light |
3rd brake light |
partwerks |
Jan 24 2015, 09:05 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
I'd like to add a 3rd brake light, and do like the one I have on the Jetta, but looks like I would be brake light challenged to even begin to mount/make that work? Probably wouldn't work, as it was designed to be inside.
http://www.ebay.com/itm/93-94-95-96-97-VW-...f4e&vxp=mtr |
Tom_T |
Jan 24 2015, 09:10 PM
In another Garage post a few weeks ago I posted one that I put on our `88 Westy which basically adheres to the inside of the glass, & a bunch of others added in other ideas too.
Here ya go! http://www.914world.com/bbs2/index.php?sho...=247560&st= (IMG:style_emoticons/default/beerchug.gif) |
Jan 25 2015, 12:59 PM
Resident German Group: Admin Posts: 41,606 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Search ...
There's at least 10 old threads about various solutions for this. (IMG:style_emoticons/default/shades.gif) |
partwerks |
Jan 25 2015, 09:38 PM
I ended up going with this in red.
http://www.walmart.com/ip/Pilot-Automotive...Pieces/35680164 Only 5/16" wide with adhesive back. I'm thinking I will try and find a short piece of polished stainless tubing, or black iron, and maybe about 3/8" inside diameter, and cut out about a third of the wall lengthwise, and roll it with a bit of curve to match the roll bar with the opening facing towards the back and leave an area uncut to spot weld a tab/foot on each end a ways to use some adhesive to stick to the inside of the rear window, and then find some plugs at Ace, to cap the ends?? I think maybe I can possibly get by rolling a bit of curve in it after I cut a section out, since there won't be that much of a radius. It may possibly distort it also. We'll see. |
rmdinmd |
Jan 26 2015, 03:48 AM
Member Group: Members Posts: 488 Joined: 30-October 13 From: Greeneville,Tn Member No.: 16,585 Region Association: South East States |
a blue brake light?
bandjoey |
Jan 26 2015, 09:09 AM
bandjoey Group: Members Posts: 4,923 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Why go to all the trouble. Just stick it on. Here's the stick on 24" brake light now 3 years old. Put a rubber grommet in the chrome trim and run the wires inside. Dab of glue to seal the wires water tight, and you have a simple and large 3rd brake light.
Attached thumbnail(s) |
TC 914-8 |
Jan 27 2015, 12:20 AM
Senior Member Group: Members Posts: 807 Joined: 23-May 08 From: Sequim, WA Member No.: 9,090 Region Association: Pacific Northwest |
I ordered a roll of red LED self adhesive on ebay for 12bucks and made one for me and 10 more to give away at the WCR's
I mounted mine on the underside of the vallance to stay somewhat weather proof Attached thumbnail(s) |
913B |
Jan 27 2015, 09:19 AM
Senior Member Group: Members Posts: 845 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
How did you mount it on the underside and still be able to be visible from the rear. Did you make a wedge or something. Any chance of a close up shot of this. Thanks
wndsrfr |
Jan 27 2015, 09:35 AM
Senior Member Group: Members Posts: 1,428 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
How did you mount it on the underside and still be able to be visible from the rear. Did you make a wedge or something. Any chance of a close up shot of this. Thanks Mine are made to mount on a flat surface and be viewed from the edge.....got them from local Autozone got about $20....see the pic of Kermee in the link above.....just stuck 'em on.... |
TC 914-8 |
Jan 27 2015, 11:28 AM
How did you mount it on the underside and still be able to be visible from the rear. Did you make a wedge or something. Any chance of a close up shot of this. Thanks The shape of the LED tape is oval which makes it visible from several angles. Mounting it on the underside looks a little cleaner, hidden, and still very bright. |
913B |
What link ?
wndsrfr |
Jan 27 2015, 01:19 PM
partwerks |
Jan 27 2015, 08:16 PM
I'm thinking this might work.
I just rolled a piece of 1/2" square tubing to the curve of the roll bar, and used the plasma to cut out one side, and smoothed off the edge, and then spot welded some tabs/feet on the ends on the up side. I got a couple of square plugs to cap the end. Hopefully the tabs will tuck up in behind the roll bar pad. Plan on using that 2 sided sticky whatever it is called on the tabs to hold to the glass. |
mikesmith |
Jan 28 2015, 03:24 AM
Member Group: Members Posts: 202 Joined: 5-September 13 From: SF Member No.: 16,354 Region Association: Northern California |
Bought one of these:
http://www.ebay.com/itm/2-Pcs-17cm-Red-COB...f78&vxp=mtr (search eBay for 'red cob led bar') and stuck it to the rear window (actually jammed between the cage and the window, but you get the idea). Bright, cheap, and a spare for some other purpose later... |
partwerks |
Jan 28 2015, 08:44 AM
Is the width about 5/8"
Is it more orange, or a red in color? |
Lo-Fi Version | Time is now: 26th April 2024 - 07:01 PM |
