Wanted: Engine Cross Bar Support, Cross Bar |
91422.7 |
Jan 24 2015, 09:18 PM
Newbie Group: Members Posts: 36 Joined: 8-October 14 From: Eugene, Oregon Member No.: 17,991 Region Association: Upper MidWest |
I have a 1970 Porsche 914 which i'm installing a 1974 Porsche 914 2.0L 4cyl engine back into. I have the stock 1970 rear shift transmission. I just need the engine Cross Member Bar that supports the engine, which connects on both sides of the chassis. I'm not sure if there was a difference in the cross bar if you were using a rear shift trans vs a side shift 901 trans! Thank you
bdstone914 |
Jan 24 2015, 09:39 PM
bdstone914 Group: Members Posts: 4,514 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Yes the bar is different for a tail shift as well as the bracket that attaches it to the engine, the motor mounts and cross bar mounting hardware. I dint have a bar but should have the rest of the parts.
You are also going to have some issues with the shift linkage. The hole in the firewall for the shift rod is smaller in the side shift car. You need everything from the shifter on back. I think the ball pivot screws into the firewall of the early car. No treaded hole in the 74. |
Hank914 |
Jan 24 2015, 09:50 PM
Member Group: Members Posts: 389 Joined: 7-April 14 From: CA and OR Member No.: 17,215 Region Association: None |
PM sent. I have the tail shift setup.
91422.7 |
Jan 28 2015, 04:41 PM
I have a 1970 Porsche 914 which i'm installing a 1974 Porsche 914 2.0L 4cyl engine back into. I have the stock 1970 rear shift transmission. I just need the engine Cross Member Bar that supports the engine, which connects on both sides of the chassis. I'm not sure if there was a difference in the cross bar if you were using a rear shift trans vs a side shift 901 trans! Thank you ......*** Just wanted to say thank you for all the quick replys but one of the forum members Hank914 has everything I'm looking for at this point! Thanks again for your knowledge and help! 91422.7 (IMG:style_emoticons/default/bye1.gif) |
Lo-Fi Version | Time is now: 29th April 2024 - 03:02 PM |
