Wanted: Engine Cross Bar Support, Cross Bar |
91422.7 |
Jan 24 2015, 09:18 PM
Newbie Group: Members Posts: 36 Joined: 8-October 14 From: Eugene, Oregon Member No.: 17,991 Region Association: Upper MidWest |
I have a 1970 Porsche 914 which i'm installing a 1974 Porsche 914 2.0L 4cyl engine back into. I have the stock 1970 rear shift transmission. I just need the engine Cross Member Bar that supports the engine, which connects on both sides of the chassis. I'm not sure if there was a difference in the cross bar if you were using a rear shift trans vs a side shift 901 trans! Thank you
91422.7 |
Jan 28 2015, 04:41 PM
I have a 1970 Porsche 914 which i'm installing a 1974 Porsche 914 2.0L 4cyl engine back into. I have the stock 1970 rear shift transmission. I just need the engine Cross Member Bar that supports the engine, which connects on both sides of the chassis. I'm not sure if there was a difference in the cross bar if you were using a rear shift trans vs a side shift 901 trans! Thank you ......*** Just wanted to say thank you for all the quick replys but one of the forum members Hank914 has everything I'm looking for at this point! Thanks again for your knowledge and help! 91422.7 (IMG:style_emoticons/default/bye1.gif) |
Lo-Fi Version | Time is now: 16th May 2024 - 05:47 AM |
