Ha! We found the problem!, Zois and Milt are not going to like it |
Mark Henry |
Feb 6 2005, 02:20 PM
No index marks.
You draw a 90 degree line from the case half, then the drive is offset 12 degrees at TDC. Kind of hard to explain without a pic. You should look at the bentley when doing this. I spin the crank, cam and dizzy drive when building to make sure everything runs in the correct order. A little building tip...stick an old dizzy in, it helps with indexing and holds the dizzy drive in place. Also you can flip the engine upside-down and the drive won't fall out. |
redshift |
Feb 6 2005, 03:57 PM
Mark, I have to say your tach is UGLY, and I'd rather buy new engines, than look at it.
(IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) M |
Lo-Fi Version | Time is now: 5th May 2024 - 09:09 AM |
