| cal914 |
Jan 26 2015, 01:27 PM
Member ![]() ![]() Group: Members Posts: 321 Joined: 12-April 12 From: United Kingdom Member No.: 14,366 Region Association: None |
Is it fairly straightforward to fit a new hand brake lever link rod? I have ordered the new part as mine is bent and won't work properly. I would like to fit it myself but am not sure where to start and am a bit of a novice. Its a 1970 914.
Thanks ![]() |
| OU8AVW |
Jan 26 2015, 03:25 PM
Yacht Rigger ![]() ![]() ![]() Group: Members Posts: 1,803 Joined: 1-October 08 From: Granbury, TX Member No.: 9,601 Region Association: Southwest Region |
Is it fairly straightforward to fit a new hand brake lever link rod? I have ordered the new part as mine is bent and won't work properly. I would like to fit it myself but am not sure where to start and am a bit of a novice. Its a 1970 914. Thanks ![]() It's really a fiddley project. IIRC, the trick was moving the gear out of the way to get the rod past it. no real advice from me, just that it's doable. |
Lo-Fi Version | Time is now: 7th December 2025 - 10:51 AM |
