Goldie, new to me 92 914 1.7 |
72 IXXIV |
Jan 29 2015, 12:33 PM
Member Group: Members Posts: 62 Joined: 1-January 15 From: San Francisco Member No.: 18,277 Region Association: Northern California |
Hi Fourteeners,
I'm Chris. I just bought this gold 72 1.7 from the second owner who owned it for 40 years! It is in really amazingly well preserved *almost* rust free, *almost* original condition. It has about 70k miles on it. It lived most all of its life in the high desert of so cal, owned by an engineer who maintained it himself (with a log!). Unfortunately I didn't do a compression test on it before I bought it, and now I see that it has two cylinders at 130 and two at 165. And the 130 cylinders are not on the same side.... Anyway, I just thought I'd introduce myself. Here's a question; I think I'm going to keep driving the original, 1.7 matching numbers mill for a while. But, I'd like to put a reasonably fresh 2.0 motor in there. Any advice on my options? Long block? Used rebuild? FI v. carbs? Best, Chris |
Tom_T |
Jan 29 2015, 01:13 PM
Have you checked to see if all the valves are properly adjusted on the 2 with 130#? It could just be out of adjustment enough to cause that due to disuse by the PO or a long time since last adjustment. If it were me, I'd keep the matching nos. 1.7 in it with a car this original, & maybe punch it out to 1911 or something to get more power - & so long as it all looks stock from the outside, it will look OE, but with more power. Being the `72 1.7, even in fully stock form it will have more power than any of the later CA 1.7/1.8's & almost as much as the heavily detuned 75-76 GC 2.0's. So in the interim you may be able to just do a top-end on it or valve job - if the valves are burned. Otherwise if you go the GA 2.0, 2056 or bigger route, do save that 1.7 & store it properly. |
Lo-Fi Version | Time is now: 14th May 2024 - 01:01 PM |
