Goldie, new to me 92 914 1.7 |
72 IXXIV |
Jan 29 2015, 12:33 PM
Member Group: Members Posts: 62 Joined: 1-January 15 From: San Francisco Member No.: 18,277 Region Association: Northern California |
Hi Fourteeners,
I'm Chris. I just bought this gold 72 1.7 from the second owner who owned it for 40 years! It is in really amazingly well preserved *almost* rust free, *almost* original condition. It has about 70k miles on it. It lived most all of its life in the high desert of so cal, owned by an engineer who maintained it himself (with a log!). Unfortunately I didn't do a compression test on it before I bought it, and now I see that it has two cylinders at 130 and two at 165. And the 130 cylinders are not on the same side.... Anyway, I just thought I'd introduce myself. Here's a question; I think I'm going to keep driving the original, 1.7 matching numbers mill for a while. But, I'd like to put a reasonably fresh 2.0 motor in there. Any advice on my options? Long block? Used rebuild? FI v. carbs? Best, Chris |
Al Meredith |
Jan 29 2015, 02:30 PM
Senior Member Group: Members Posts: 960 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
Just build the engine with a 96MM "big bore "kit. Better not to use the stock heads as the 96's are too big and get very thin where they fit into the head. My recomendation is to go to "www.HAMHEADS.com" and get a set of big valve new heads with the stock spark plug locations from Len Hoffman. I have a 1911 with len's heads ,mine has a cam and 40 MM carbs and gets about 100HP. Use a stock cam if you are keeping the FI.
Lo-Fi Version | Time is now: 13th May 2024 - 05:42 PM |
