Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 127,304 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
Cool picture...
Attached image(s) ![]() |
eeyore |
Senior Member ![]() ![]() ![]() Group: Members Posts: 889 Joined: 8-January 04 From: meridian, id Member No.: 1,533 Region Association: None ![]() |
The first run chassises, chassii -- frames -- were aluminum, magnesium came later. The orginal design also used the frame tubes for oil piping up to the front cooler. JWA did away with that the 2nd year of the car, and individually plumbed the oil lines.
The 16 was unfeasible because of weight and size. The length of the motor would have really changed the turning moment of the car, already sketchy under Piech's no wing 'drag is bad' philosophy. Also, the 917's life was coming to an end under FIM rules. CanAm required a much better hp/ton figure which was only gained with turbos. As for the length of the crank on the 16, that shouldn't have been a problem. On the 12s, power was taken from the crank at the middle of the engine. Crankwise, it was like havint 2 flat sixes end to end. They probably carried over this element over to the 16 as well. |
BigD9146gt |
OCD member ![]() ![]() Group: Members Posts: 376 Joined: 24-January 05 From: Sydney, Australia Member No.: 3,502 Region Association: Australia and New Zealand ![]() |
Sammy, thats some pro- picking nutting giong on here (IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif) . Honestly, i re-read my posts and i apologize if i came across rude. I need to use more (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) in my posts, cause i'm staight to the point, but not worked up about it either.
To your point about filling the chassis with air or nitrogen, i agree. (but you wouldn't want to fill it with air anyways because of possible corrosion properties. Purging it with the inert gas is a very good idea, and helium makes a great candidate. Hey, hydrogen's even lighter! To bad Porsche didn't work on the Hindinburg, they'd saved some lives with logic. (IMG:http://www.914world.com/bbs2/html/emoticons/wavey.gif) |
Quilmes |
Torino 380 W ![]() ![]() Group: Members Posts: 358 Joined: 26-January 05 From: Orlando, FL Member No.: 3,510 ![]() |
908 engine photo from Rennsport II Daytona
Quilmes |
Here is one from a 917-30
eeyore |
How much weight gets added in bungs, gauge and plumbing?
andys |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None ![]() ![]() |
I didn't want to mention something based on vague recollection (the 30+ y/o memories), but it was said, at the time, it revealed cracks in the chassis'. That would be a pretty important bit of info in a 200+ MPH car! Perhaps it did serve a secondary purpose, like back filling with helium/argon for welding during the fabrication process. Camping out at RIR was great fun, in those years. Did it many times; watched many races there. I really enjoyed the freedom of walking the pits, and literally rubbing elbows with some of the great's. Shelby, Donohue, Penske, Hunt (James), Mario, Unser, Fittipaldi, Foyt, Parnelli, etc; very casual atmosphere. Lot's of celeb's too. I ran many laps there in a Shifter Kart; great fun! Andy |
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,289 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
The real reason that helium was used in the frame is that helium is the smallest molecule. That means that the smallest of leaks or cracks could be detected. Helium is often used for leak detection due to the small molecule size. Why not hydrogen? Well, hydrogen molecule is H2 whereas helium is He. That is helium is a single atom, and hydrogen is two atoms and hence much larger.
URY914 |
I knew that. (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
andys |
It hadn't occured to me, but this would be a good way to test the chassis for weld joint integrity by sniffing for helium (by using He detection equipment, of course (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) ). That said, it would seem to me pretty tough to maintain He pressurized in a chassis for very long. I've done a lot of He leak testing on welded SS and Ti devices for hermeticity, but never anything with welded alum. Anyone have experience with it? Andy |
eeyore |
Sorry. How about this for a mea culpa? I heard that after a race, the crew would fill the chassis with oxy-acetylene at 100psi. Then they'd check every joint with a lighter. Any crack would become a mini blowtorch and weld the crack closed from the inside. |
physician |
still looking for a teener.... ![]() ![]() Group: Members Posts: 86 Joined: 19-March 04 From: quebec Member No.: 1,819 ![]() |
the good thing about using helium is that you dont need fancy equpment to detect a leak... if your voice sound funny, there is a leak! (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) mouhaha
nevermind.. i like the creativity in that (IMG:http://www.914world.com/bbs2/html/emoticons/clap.gif) |
BigD9146gt |
I personally like how in the pictures of the 917 engine, they take a picture of Carl and his helper putting the heads/cam towers on... but its going on up-side down (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
(IMG:http://www.914world.com/bbs2/html/emoticons/chairfall.gif) |
Lo-Fi Version | Time is now: 4th July 2025 - 09:18 AM |
