persistent window gap 1970, window doesn't seat into the rubber |
pgollender |
Feb 7 2015, 10:11 AM
Member Group: Members Posts: 189 Joined: 5-July 11 From: Sacramento Member No.: 13,281 Region Association: Northern California |
After installing my windows and re-conditioning the 1970 roll-up mechanism last year and adding some new 914 rubber all the way around, I have two persistent gaps where the window does not seat into the top rubber. The body is straight, does not sag and the door gaps and door height are all aligned and uniform so it is not the body. How do I adjust these gaps?
mskala |
Feb 7 2015, 11:09 AM
After installing my windows and re-conditioning the 1970 roll-up mechanism last year and adding some new 914 rubber all the way around, I have two persistent gaps where the window does not seat into the top rubber. The body is straight, does not sag and the door gaps and door height are all aligned and uniform so it is not the body. How do I adjust these gaps? I have something similar although I haven't put in the time to figure it out. 914rubber windshield and side top seal. I suspect the design of the side pieces changed in later years and maybe there is a fitment issue if you don't have a targa top of the same vintage? (IMG:style_emoticons/default/confused24.gif) |
bandjoey |
Feb 7 2015, 01:04 PM
bandjoey Group: Members Posts: 4,923 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Search window adjustment. Several threads on this already. On my phone or I would do it for you. Most cars have adjusting screws at the bottom of the door.
(IMG:style_emoticons/default/biggrin.gif) |
VaccaRabite |
Feb 7 2015, 04:45 PM
En Garde! Group: Admin Posts: 13,420 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I have the exact same gaps.
Zach |
IronHillRestorations |
Feb 7 2015, 06:42 PM
Looks like the side seal is the wrong profile (too tall) and preventing the window from going all the way up.
57lincolnman |
Feb 7 2015, 09:09 PM
Member Group: Members Posts: 174 Joined: 14-September 10 From: Los Angeles Member No.: 12,175 Region Association: Southern California |
After installing my windows and re-conditioning the 1970 roll-up mechanism last year and adding some new 914 rubber all the way around, I have two persistent gaps where the window does not seat into the top rubber. The body is straight, does not sag and the door gaps and door height are all aligned and uniform so it is not the body. How do I adjust these gaps? I had a similar problem at the windshield (front edge of the side window. That gap is particularly troublesome because water drips right there and onto your knee when it rains. I solved the problem by taking some black window insulation that I bought at Lowe's. It has a flat side with adhesive tape. To keep the profile I threaded a coat hangar into the open slot and bent it to the inside windshield frame. The vent window closes into this space. The insulation is soft enough to give when the door is closed and fill the gap. If this is helpful to you, let me know and I'll send a picture. |
Valy |
Feb 8 2015, 06:27 PM
Senior Member Group: Members Posts: 1,671 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
This is how the original looks. The outer lip of the side Targa lip is shorter than the inner one, it's even a bit shorter than the windshield to Targa side lip. Could it be that you mixed left and right seals ? Attached thumbnail(s) |
era vulgaris |
Feb 8 2015, 07:09 PM
J is for Genius Group: Members Posts: 982 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
After installing my windows and re-conditioning the 1970 roll-up mechanism last year and adding some new 914 rubber all the way around, I have two persistent gaps where the window does not seat into the top rubber. The body is straight, does not sag and the door gaps and door height are all aligned and uniform so it is not the body. How do I adjust these gaps? It looks like your window is not adjusted to it's maximum height. But it also looks like your triangle-window isn't either. I don't think there should be that large of a gap between your triangle-window and the main targa seal. Your window should also be able to roll all the way up to the top of the triangle-window seal, so the top of the window is the same height as the black triangle window seal on the door. Yours is not. I used the same 914rubber main targa seal and side seals on my old 72 (same regulator style as yours), and they sealed the car up perfectly. |
bandjoey |
Feb 8 2015, 07:57 PM
http://forums.pelicanparts.com/porsche-914...-alignment.html
http://rennlist.com/forums/993-forum/74581...or-windows.html And last but not least. (IMG:style_emoticons/default/lol-2.gif) Attached image(s) |
Feb 8 2015, 08:10 PM
You can adjust the window all you want, but that's not going to fix the difference in height between the frame seal and the roof seal, there's just too much difference in the seals.
Mikey914 |
Feb 9 2015, 12:05 PM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
The seal I make is slightly taller, it is like the superseded seal. The outer lip is designed to sweep over the outer scraper, and provide an additional barrier. This is one of the improvements the factory made to help keep water out.
Mikey914 |
Feb 9 2015, 12:11 PM
The problem looks like the window isn't quite as "tall" as it could be. This is an adjustment issue. It should look like this. This is shown with the main targa seal not in place
Feb 9 2015, 10:10 PM
OK, so the glass is supposed to fit between the flap and the main profile. Got it.
So judging by the pictures, he needs to take off the door panel, and adjust the window stop so the glass goes higher. There's an M6 cap screw (10mm hex) with a jam nut that stops the window when it's rolled up all the way, so he'll need to screw that in to get it set to the correct height. He may also have to adjust the tilt which is at the bottom of the door, with a 13mm hex jam nut on a slotted stud. Then he may have to move the seal channel on the roof outboard a little so the glass fits in the groove properly. |
pgollender |
Feb 9 2015, 11:43 PM
After installing my windows and re-conditioning the 1970 roll-up mechanism last year and adding some new 914 rubber all the way around, I have two persistent gaps where the window does not seat into the top rubber. The body is straight, does not sag and the door gaps and door height are all aligned and uniform so it is not the body. How do I adjust these gaps? It looks like your window is not adjusted to it's maximum height. But it also looks like your triangle-window isn't either. I don't think there should be that large of a gap between your triangle-window and the main targa seal. Your window should also be able to roll all the way up to the top of the triangle-window seal, so the top of the window is the same height as the black triangle window seal on the door. Yours is not. I used the same 914rubber main targa seal and side seals on my old 72 (same regulator style as yours), and they sealed the car up perfectly. Do you have a picture of your seals/window interface ? Here are some additional measurements as it sits mal-adjusted: From the door vertically it is 14-3/8" inches in the front Here it is when I push it up: look closely you can see it by the exposed washer marks: And 14-3/16" in the back looks like I need 1/4 to 5/16" taller to fit into the top groove in Mikey's redesigned rubber. What are the top up measurements of other members cars ? Furthermore the window is absolutely tight against the new triangle window seal which allows for no further travel upwards. I did notice that the front window frame has a small plate that can be adjusted up or down about 1/4"effectively raising the front of the window by 1/4". I'm not sure if this will solve the sag in the rear end. I did notice that the clamp that holds the bottom of the window could probably be shimmed fairly easily by adding some butyl or maybe 3M tape. I'll try this weekend and post the results . (IMG:style_emoticons/default/stirthepot.gif) |
Lo-Fi Version | Time is now: 20th April 2024 - 02:43 AM |
