persistent window gap 1970, window doesn't seat into the rubber |
pgollender |
Feb 7 2015, 10:11 AM
Member Group: Members Posts: 193 Joined: 5-July 11 From: Sacramento Member No.: 13,281 Region Association: Northern California |
After installing my windows and re-conditioning the 1970 roll-up mechanism last year and adding some new 914 rubber all the way around, I have two persistent gaps where the window does not seat into the top rubber. The body is straight, does not sag and the door gaps and door height are all aligned and uniform so it is not the body. How do I adjust these gaps?
mskala |
Feb 7 2015, 11:09 AM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
After installing my windows and re-conditioning the 1970 roll-up mechanism last year and adding some new 914 rubber all the way around, I have two persistent gaps where the window does not seat into the top rubber. The body is straight, does not sag and the door gaps and door height are all aligned and uniform so it is not the body. How do I adjust these gaps? I have something similar although I haven't put in the time to figure it out. 914rubber windshield and side top seal. I suspect the design of the side pieces changed in later years and maybe there is a fitment issue if you don't have a targa top of the same vintage? (IMG:style_emoticons/default/confused24.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 06:20 PM |
