Variations of the VW Cabin / Dome Light |
tweet |
Feb 10 2015, 10:26 AM
Member Group: Members Posts: 200 Joined: 25-February 13 From: South Florida Member No.: 15,579 Region Association: South East States |
Okay, so I've been collecting interior lights for the past year and have been thinking of doing this for a while. So some of you may be irked by my next statement, but it is factual. There is truly no such thing as a Porsche 914 interior light. All of these lights carry a VW part designation and the VW light was already in mass production before the first 914 was ever built. But, I see the topic come up from time to time as to which light is for a 914? All of these lights can be used in a 914 application, some with a minor mod electrically speaking, others are plug 'n play.
The light which is branded "Hella", "VW", "Made in Germany" with a white square button and chrome edge is the one typically found on 914's imported to the US market. The Sidler light was also made in Germany and Saturnus was made in Yugoslavia. Hella later acquired Saturnus and is now known as Hella - Saturnus. All of the lights below, to my knowledge however, are authentic authorized OEM VW parts. So, if you need to be period correct, you would get a white square button, chrome edge light. If you just need to be able to see in the dark, any will do just fine. BTW, there are other lights out there, but they are typically aftermarket, non-VW, non-OEM reproductions. Let the debate begin... Attached thumbnail(s) |
JeffBowlsby |
Feb 10 2015, 10:31 AM
914 Wiring Harnesses Group: Members Posts: 8,478 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Excellent work and documentation!
barefoot |
Feb 10 2015, 10:33 AM
Senior Member Group: Members Posts: 1,269 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
The apparently OEM one that came in my 76 (trashed & not usable) had a 3 pole switch which could apparently be switched on either by opening a door, or manually at the light.
I purchased a replacement for ~ $12 that is only a 2 pole, so have wired it only as manual, not connected to door switches. |
Mark Henry |
Feb 10 2015, 11:23 AM
Since these would have been whatever was on the VW shelf that year of production there is very likely differences from 1969 build date 914's till 1976.
The first one (left) is likely not even a 914 light, but a beetle pre 1966 6v light. The last 3 lights likely for mexican and brazil built beetles in the 80s and 90's . BTW as you guessed these are not "914" lights, they are all off the shelf VW beetle type 1 interior light housings. They have VW beetle part numbers. |
ChrisFoley |
Feb 10 2015, 12:18 PM
I am Tangerine Racing Group: Members Posts: 7,909 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
914 Factory Parts Catalog shows the P/N as: 111.947.111D
The "111" designates the first vehicle it was used on - early Beetle. |
Mark Henry |
Feb 10 2015, 12:41 PM
You will find this on a lot of 914 parts.
Door window handles for example, the early chrome strip handle, that I have seen some asking a premium price for, are common VW type 3 handles. Later they are common VW bug part. 111 xxx xxx 113 xxx xxx 141 xxx xxx 151 xxx xxx 211 xxx xxx 311 xxx xxx 411 xxx xxx 021 xxx xxx 022 xxx xxx likely more All VW part numbers. Any consolation you see 111 and 113 part numbers in 356 and early 911 cars. The 911 engine intermediate shaft bearings, right into the 1990's, are common type 1 and 4 cam bearings with different hole drillings. |
JeffBowlsby |
Feb 10 2015, 12:53 PM
You will find this on a lot of 914 parts. Door window handles for example, the early chrome strip handle, that I have seen some asking a premium price for, are common VW type 3 handles. Later they are common VW bug part. 111 xxx xxx 113 xxx xxx 141 xxx xxx 151 xxx xxx 211 xxx xxx 311 xxx xxx 411 xxx xxx 021 xxx xxx 022 xxx xxx likely more All VW part numbers. Any consolation you see 111 and 113 part numbers in 356 and early 911 cars. The 911 engine intermediate shaft bearings, right into the 1990's, are common type 1 and 4 cam bearings with different hole drillings. No way...you mean my Porsh uses Vdub parts? I'm selling out.... :gasp: |
Mark Henry |
Feb 10 2015, 12:59 PM
You will find this on a lot of 914 parts. Door window handles for example, the early chrome strip handle, that I have seen some asking a premium price for, are common VW type 3 handles. Later they are common VW bug part. 111 xxx xxx 113 xxx xxx 141 xxx xxx 151 xxx xxx 211 xxx xxx 311 xxx xxx 411 xxx xxx 021 xxx xxx 022 xxx xxx likely more All VW part numbers. Any consolation you see 111 and 113 part numbers in 356 and early 911 cars. The 911 engine intermediate shaft bearings, right into the 1990's, are common type 1 and 4 cam bearings with different hole drillings. No way...you mean my Porsh uses Vdub parts? I'm selling out.... :gasp: Yes way (IMG:style_emoticons/default/shades.gif) Trying to edumakate da youngin's.... I see a lot of very common VW parts being sold as "rare porsche". But to the OP I agree the late lights may be "real" VW and the correct part # but they do fit like total crap and don't look the same. |
dlkawashima |
Feb 10 2015, 01:21 PM
914 Guru Group: Members Posts: 9,749 Joined: 1-October 10 From: San Jose Member No.: 12,234 Region Association: Northern California |
Yeah, there's very little to debate. It's well known that the dome light used on the 914 was used first on VW Bugs.
The only thing I question is if the Saturnus dome light was ever installed at the factory. While there is evidence the Saturnus was installed on Yugoslavian Bugs, I've seen no evidence of it ever being factory installed on 914s. Steve Gaglione once said over in the Originality and History sub-forum that the Sidler was installed on the very earliest of 914s coming off the assembly line, and then white switch Hellas for the rest of the production. So if you're looking for the correct dome light and have anything other than a very, very early (as in 1969 build date) 914, get a white switch Hella. Here's another short thread about my search for the name of the "S" dome light: http://www.914world.com/bbs2/index.php?act...=2&t=183993 Here's a better look at the three "correct" dome lights (white switch with chrome edge). Saturnus - Sidler - Hella. Click image to supersize. Oh, and my Sidler dome light, while solid, had almost no "chrome" left on its edge. I used Spaz Stix Ultimate Mirror Chrome to restore the finish. |
Chris Pincetich |
Feb 10 2015, 02:03 PM
B-) Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
I don't think new ones "Made in Germany" are still available. No? (IMG:style_emoticons/default/sad.gif) I want one that is more OEM than the one I have in there (IMG:style_emoticons/default/biggrin.gif) |
JawjaPorsche |
Feb 10 2015, 02:40 PM
Advanced Member Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
(IMG:style_emoticons/default/beerchug.gif) I don't think new ones "Made in Germany" are still available. No? (IMG:style_emoticons/default/sad.gif) I want one that is more OEM than the one I have in there (IMG:style_emoticons/default/biggrin.gif) Be prepare to have deep pockets. If you can find one in good condition, it will probably sell for over $100. |
dlkawashima |
Feb 10 2015, 02:57 PM
(IMG:style_emoticons/default/beerchug.gif) I don't think new ones "Made in Germany" are still available. No? (IMG:style_emoticons/default/sad.gif) I want one that is more OEM than the one I have in there (IMG:style_emoticons/default/biggrin.gif) Be prepare to have deep pockets. If you can find one in good condition, it will probably sell for over $100. Only if it's a Hella AND someone wants to rip you off. |
MikeInMunich |
Member Group: Members Posts: 392 Joined: 19-November 13 From: Munich, Germany Member No.: 16,674 Region Association: None |
Excellent work and documentation! (IMG:style_emoticons/default/agree.gif) Nice work Tweet. Hope the move stress is over. (IMG:style_emoticons/default/beerchug.gif) |
Tom_T |
Feb 10 2015, 05:12 PM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
This is really good info on the dome lights! (IMG:style_emoticons/default/smilie_pokal.gif)
.... a couple of additional clarifications though, & forgive me if they were covered above, but I didn't see them .... Actually, the Hella made for VW-Porsche 914 square white button/"chrome" edge ones made during the run for the 914's from 1969-1976 would have said - "Made in West Germany" - since the wall didn't fall until `88 & German reunification after that! (IMG:style_emoticons/default/smile.gif) IIRC, it was in the early 1980's when the Porsche dealerships started selling the square black button version only for replacements. For functionality those sold 3-pole by any vW or Porsche supplier today works fine. Being fragile plastic, subject to damage from elbows/etc. mounted on the backpad + heat damage from too strong/hot of a lamp/bulb - these were replaced more often than almost any other part on the 914 (other than regular maintenance & wear items). Also to clarify for the newbies, the "chrome" edge is actually a silver/chrome paint applied to the underside of the plastic lens edge - not a separate chrome bezel - just so nobody goes crazy hunting for that! (IMG:style_emoticons/default/biggrin.gif) Cheers! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
dlkawashima |
Feb 10 2015, 05:45 PM
Actually, the Hella made for VW-Porsche 914 square white button/"chrome" edge ones made during the run for the 914's from 1969-1976 would have said - "Made in West Germany" - since the wall didn't fall until `88 & German reunification after that! (IMG:style_emoticons/default/smile.gif) You'd think it would say "West Germany" but it actually says "Made in Germany" ... look again closely at the image I posted. (Click the image to super size it). The Hella dome light is the one on the right. |
TJB/914 |
Feb 10 2015, 09:32 PM
Mid-Engn. Group: Members Posts: 4,326 Joined: 24-February 03 From: Plymouth & Petoskey, MI Member No.: 346 Region Association: Upper MidWest |
This is really good info on the dome lights! (IMG:style_emoticons/default/smilie_pokal.gif) .... a couple of additional clarifications though, & forgive me if they were covered above, but I didn't see them .... Actually, the Hella made for VW-Porsche 914 square white button/"chrome" edge ones made during the run for the 914's from 1969-1976 would have said - "Made in West Germany" - since the wall didn't fall until `88 & German reunification after that! (IMG:style_emoticons/default/smile.gif) IIRC, it was in the early 1980's when the Porsche dealerships started selling the square black button version only for replacements. For functionality those sold 3-pole by any vW or Porsche supplier today works fine. Being fragile plastic, subject to damage from elbows/etc. mounted on the backpad + heat damage from too strong/hot of a lamp/bulb - these were replaced more often than almost any other part on the 914 (other than regular maintenance & wear items). Also to clarify for the newbies, the "chrome" edge is actually a silver/chrome paint applied to the underside of the plastic lens edge - not a separate chrome bezel - just so nobody goes crazy hunting for that! (IMG:style_emoticons/default/biggrin.gif) Cheers! (IMG:style_emoticons/default/beerchug.gif) Tom /////// Good review Tom, Here's a photo front & rear of an real one for the record. I have one broken in half I am trying to glue together, grrrrrr. (IMG:style_emoticons/default/idea.gif) Tom Attached thumbnail(s) Attached image(s) |
JeffBowlsby |
Feb 10 2015, 09:54 PM
This photo breaks my heart. Like seeing an abused child.
How many more milliseconds would it have taken someone to simply pull the disconnects off the light? But no...they had to cut wires... Attached image(s) |
mepstein |
Feb 10 2015, 10:13 PM
914-6 GT in waiting Group: Members Posts: 19,239 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
(IMG:style_emoticons/default/beerchug.gif) I don't think new ones "Made in Germany" are still available. No? (IMG:style_emoticons/default/sad.gif) I want one that is more OEM than the one I have in there (IMG:style_emoticons/default/biggrin.gif) Be prepare to have deep pockets. If you can find one in good condition, it will probably sell for over $100. Only if it's a Hella AND someone wants to rip you off. Funny - I just sold one for $100, had 3 people "2nd" in line, One offered $150 but I stuck with the original buyer at the asking price. No one had a gun to their head. My feeling - It's only a rip off if you don't get what you expect. We all have our perceived value. |
dlkawashima |
Feb 10 2015, 11:06 PM
No, it's not funny when someone buys a dome light for $35 and then turns around and sells it for $150 plus. That's just ripping off your fellow 914 World member and laughing all the way to the bank. Not saying it's you but I know it's been done.
You want to know where you can get one? Bug swap meets, TheSamba, bug shops that sell used stuff. Example: https://www.bugcity.com/shop/shop.htm?pquery=dome+light |
913B |
Feb 10 2015, 11:56 PM
Senior Member Group: Members Posts: 845 Joined: 25-April 05 From: South Bay/SoCal Member No.: 3,983 Region Association: None |
Nice write up. Thank you for the information.
Lo-Fi Version | Time is now: 25th April 2024 - 06:01 PM |
