Just arrived in the garage: 1971 914-4 1.7 |
raynekat |
Feb 11 2015, 07:22 PM
Advanced Member Group: Members Posts: 2,157 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Bought a 71 1.7 liter today.
Car is in relatively good shape as far as I can tell. Likely some hell hole and rear portion of the back trunk rust repair needed, but appears to be minor. Time will tell. My current plans are to get the fuel system and FI sorted out (me). It cranks over, but doesn't start. Then go through the brakes from stem to stern (PMB). After that....drive it. The original color is light ivory, but has had a repaint in pearl white years ago. Will get the body work done and do a proper respray. I've already got a set of 15x6.5" Minilites to install. The suspension will get a good going over....likely Elephant Racing setup. Re-do the interior with a more supportive driver's seat. Refreshed gauges (Hollywood Speedo) in 356 fashion. Double wrapped RS steering wheel. GT lightwt door panels. Eventually, a bigger four will power the car. Would like to keep it all 4 cylinder for the time being. I've already got a 911 sitting in the garage that tics all the 911 boxes off. I'll keep a log of the progress here with pics. This is a big, big project.....no doubt. |
cary |
Jul 29 2016, 09:13 PM
Advanced Member Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest |
Still hot ..................90 degrees when we left at 5pm.
Started the day with grinding down the inside trunk corner patches. After the grinding and sanding was finished I coated them with cold galvanizing. While cold galvanizing was drying I sprayed down the trunk support panel with OSPHO. Getting it ready for a rub down with a red scour pad and an application of cold galvanizing. |
cary |
Sep 5 2016, 09:10 PM
While cold galvanizing was drying I sprayed down the trunk support panel with OSPHO. Getting it ready for a rub down with a red scour pad and an application of cold galvanizing. Took a couple minutes and tidied up the OSPHO and gave the panel a layer of cold galvanizing. |
Lo-Fi Version | Time is now: 5th May 2024 - 02:45 AM |
