Just arrived in the garage: 1971 914-4 1.7 |
raynekat |
Feb 11 2015, 07:22 PM
Advanced Member Group: Members Posts: 2,153 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Bought a 71 1.7 liter today.
Car is in relatively good shape as far as I can tell. Likely some hell hole and rear portion of the back trunk rust repair needed, but appears to be minor. Time will tell. My current plans are to get the fuel system and FI sorted out (me). It cranks over, but doesn't start. Then go through the brakes from stem to stern (PMB). After that....drive it. The original color is light ivory, but has had a repaint in pearl white years ago. Will get the body work done and do a proper respray. I've already got a set of 15x6.5" Minilites to install. The suspension will get a good going over....likely Elephant Racing setup. Re-do the interior with a more supportive driver's seat. Refreshed gauges (Hollywood Speedo) in 356 fashion. Double wrapped RS steering wheel. GT lightwt door panels. Eventually, a bigger four will power the car. Would like to keep it all 4 cylinder for the time being. I've already got a 911 sitting in the garage that tics all the 911 boxes off. I'll keep a log of the progress here with pics. This is a big, big project.....no doubt. |
cary |
Jul 7 2016, 09:17 PM
I decide its time to start using the plasma cutter for the cutting tasks its designed for.
Steve, one of my co-workers at Rothsport said changing the tip every time you use it is the primary issue I've been having. Easy Deal .................... Big bite ......................... I discover that a portion of the tow hook brace is missing on the donor panel. I'll need to cut it off the original tail light panel piece. There's a couple wicked welds were the tube is welded to the support frame. I'll have to see if I can delicately cut them out with new plasma cutting skills. |
Lo-Fi Version | Time is now: 20th April 2024 - 06:53 AM |
