Just arrived in the garage: 1971 914-4 1.7 |
raynekat |
Feb 11 2015, 07:22 PM
Advanced Member Group: Members Posts: 2,153 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Bought a 71 1.7 liter today.
Car is in relatively good shape as far as I can tell. Likely some hell hole and rear portion of the back trunk rust repair needed, but appears to be minor. Time will tell. My current plans are to get the fuel system and FI sorted out (me). It cranks over, but doesn't start. Then go through the brakes from stem to stern (PMB). After that....drive it. The original color is light ivory, but has had a repaint in pearl white years ago. Will get the body work done and do a proper respray. I've already got a set of 15x6.5" Minilites to install. The suspension will get a good going over....likely Elephant Racing setup. Re-do the interior with a more supportive driver's seat. Refreshed gauges (Hollywood Speedo) in 356 fashion. Double wrapped RS steering wheel. GT lightwt door panels. Eventually, a bigger four will power the car. Would like to keep it all 4 cylinder for the time being. I've already got a 911 sitting in the garage that tics all the 911 boxes off. I'll keep a log of the progress here with pics. This is a big, big project.....no doubt. |
cary |
Jul 7 2016, 09:41 PM
Then on to removing the exhaust shield from the old trunk panel.
Then I discover that the last person that removed the exhaust shield didn't have a MIG welder. The supports were brazed to the bottom of the trunk panel. So they have to be separated with a torch. Get that done and then run the stand offs thru the bead blaster. They'll need a little refurbishing. Then I decide that the exhaust shield needs to be taken outside and sand blasted. It's filthy. Covered in oil and dirt. After the dirt and oil are removed it looks like its been beat on with a hammer. I did remove all the odds and ends off the old tail light panel. You never know what one might need in the future. |
Lo-Fi Version | Time is now: 19th April 2024 - 01:36 PM |
