Just arrived in the garage: 1971 914-4 1.7 |
raynekat |
Feb 11 2015, 07:22 PM
Advanced Member Group: Members Posts: 2,154 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Bought a 71 1.7 liter today.
Car is in relatively good shape as far as I can tell. Likely some hell hole and rear portion of the back trunk rust repair needed, but appears to be minor. Time will tell. My current plans are to get the fuel system and FI sorted out (me). It cranks over, but doesn't start. Then go through the brakes from stem to stern (PMB). After that....drive it. The original color is light ivory, but has had a repaint in pearl white years ago. Will get the body work done and do a proper respray. I've already got a set of 15x6.5" Minilites to install. The suspension will get a good going over....likely Elephant Racing setup. Re-do the interior with a more supportive driver's seat. Refreshed gauges (Hollywood Speedo) in 356 fashion. Double wrapped RS steering wheel. GT lightwt door panels. Eventually, a bigger four will power the car. Would like to keep it all 4 cylinder for the time being. I've already got a 911 sitting in the garage that tics all the 911 boxes off. I'll keep a log of the progress here with pics. This is a big, big project.....no doubt. |
cary |
Jul 11 2016, 09:50 PM
Monday AM :
Pulled out the torch cart and started with the remainder of the left tail light panel. The car had been hit in the rear and been poorly repaired on the past. The entire tail light panel was brazed in, not welded. Then started working my way around the remainder of the trunk panel. Then on to removing the center reinforcement panel. Making my way into the right corner. We're finding the inner fender above the trunk panel is pretty wrinkled on both sides. I may look at cutting both back corners out of my parts car. We need the fender support straps too. End of the day ......................... got farther than I thought I would. Doug stopped by to check on the progress and go out to lunch. |
Lo-Fi Version | Time is now: 26th April 2024 - 10:06 PM |
