Just arrived in the garage: 1971 914-4 1.7 |
raynekat |
Feb 11 2015, 07:22 PM
Advanced Member Group: Members Posts: 2,154 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Bought a 71 1.7 liter today.
Car is in relatively good shape as far as I can tell. Likely some hell hole and rear portion of the back trunk rust repair needed, but appears to be minor. Time will tell. My current plans are to get the fuel system and FI sorted out (me). It cranks over, but doesn't start. Then go through the brakes from stem to stern (PMB). After that....drive it. The original color is light ivory, but has had a repaint in pearl white years ago. Will get the body work done and do a proper respray. I've already got a set of 15x6.5" Minilites to install. The suspension will get a good going over....likely Elephant Racing setup. Re-do the interior with a more supportive driver's seat. Refreshed gauges (Hollywood Speedo) in 356 fashion. Double wrapped RS steering wheel. GT lightwt door panels. Eventually, a bigger four will power the car. Would like to keep it all 4 cylinder for the time being. I've already got a 911 sitting in the garage that tics all the 911 boxes off. I'll keep a log of the progress here with pics. This is a big, big project.....no doubt. |
cary |
Jul 30 2016, 11:14 PM
Began with cutting the right corner of the trunk panel to create the extension needed to fill out the corner.
Basically cut it right in front of the vertical flange. This will allow me to swing the vertical portion out to the wall were it needs to be. This is the extension needed to get the correct fit. I use numerous shapes and sizes of brass backers to assist in welding in the large gaps/areas. Here is the finished work. Before and after grinding. You don't need to get too carried away with grinding. Most of the new extension will be covered with seam sealer. Attached image(s) |
Lo-Fi Version | Time is now: 26th April 2024 - 03:27 AM |
