Just arrived in the garage: 1971 914-4 1.7 |
raynekat |
Feb 11 2015, 07:22 PM
Advanced Member Group: Members Posts: 2,146 Joined: 30-December 14 From: BORING, Oregon Member No.: 18,263 Region Association: Pacific Northwest |
Bought a 71 1.7 liter today.
Car is in relatively good shape as far as I can tell. Likely some hell hole and rear portion of the back trunk rust repair needed, but appears to be minor. Time will tell. My current plans are to get the fuel system and FI sorted out (me). It cranks over, but doesn't start. Then go through the brakes from stem to stern (PMB). After that....drive it. The original color is light ivory, but has had a repaint in pearl white years ago. Will get the body work done and do a proper respray. I've already got a set of 15x6.5" Minilites to install. The suspension will get a good going over....likely Elephant Racing setup. Re-do the interior with a more supportive driver's seat. Refreshed gauges (Hollywood Speedo) in 356 fashion. Double wrapped RS steering wheel. GT lightwt door panels. Eventually, a bigger four will power the car. Would like to keep it all 4 cylinder for the time being. I've already got a 911 sitting in the garage that tics all the 911 boxes off. I'll keep a log of the progress here with pics. This is a big, big project.....no doubt. |
cary |
Aug 18 2016, 09:06 PM
Picked up the donor car this am ...............
This is the first car that I think had spent it's entire life in California. There is no rust in the sail panels. Only two little spots from the foam over the passengers door handle. Front hood has no visible rust under the rolled edge. The front trunk seal channel is bitch'n. But it has fairly aggressive damage from the battery acid. Rear trunk was cut for the V6. But not removed. So it could be re-welded. Doug we got your seat belt retractor pockets too ....................... Top is going to the dump. Big crack right down the middle. Extra front end. We got 3 of the rear wheels. |
Lo-Fi Version | Time is now: 29th March 2024 - 06:32 AM |
