Just arrived in the garage: 1971 914-4 1.7 |
raynekat |
Feb 11 2015, 07:22 PM
Advanced Member Group: Members Posts: 2,153 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Bought a 71 1.7 liter today.
Car is in relatively good shape as far as I can tell. Likely some hell hole and rear portion of the back trunk rust repair needed, but appears to be minor. Time will tell. My current plans are to get the fuel system and FI sorted out (me). It cranks over, but doesn't start. Then go through the brakes from stem to stern (PMB). After that....drive it. The original color is light ivory, but has had a repaint in pearl white years ago. Will get the body work done and do a proper respray. I've already got a set of 15x6.5" Minilites to install. The suspension will get a good going over....likely Elephant Racing setup. Re-do the interior with a more supportive driver's seat. Refreshed gauges (Hollywood Speedo) in 356 fashion. Double wrapped RS steering wheel. GT lightwt door panels. Eventually, a bigger four will power the car. Would like to keep it all 4 cylinder for the time being. I've already got a 911 sitting in the garage that tics all the 911 boxes off. I'll keep a log of the progress here with pics. This is a big, big project.....no doubt. |
cary |
Oct 22 2016, 12:08 PM
Advanced Member Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest |
Friday was spent prepping the parts cut out of the donor car. Note : The parts were cut out intentionally large to allow me to work from the backside. This will allow me to do the least amount of damage to the parent material of the part being used on the car.
Step One : Remove all seam sealer with heat gun and small and medium wood chisel. Step Two : Cut down back side of spot welds with cutter. Step Three : Pop off cut spot welds with small wood chisel Engineering Plan : After all the dust has cleared from the sawing. Determined that the pocket will be trimmed to fit. 1. Top portion will lay on the cross brace and be rosette welded in. 2. If I can, the outer and bottom weld to be lap welded with rosette and seam welds. Most of the busy work will be under the interior back pad. |
Lo-Fi Version | Time is now: 24th April 2024 - 11:53 AM |
