Just arrived in the garage: 1971 914-4 1.7 |
raynekat |
Feb 11 2015, 07:22 PM
Advanced Member Group: Members Posts: 2,153 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Bought a 71 1.7 liter today.
Car is in relatively good shape as far as I can tell. Likely some hell hole and rear portion of the back trunk rust repair needed, but appears to be minor. Time will tell. My current plans are to get the fuel system and FI sorted out (me). It cranks over, but doesn't start. Then go through the brakes from stem to stern (PMB). After that....drive it. The original color is light ivory, but has had a repaint in pearl white years ago. Will get the body work done and do a proper respray. I've already got a set of 15x6.5" Minilites to install. The suspension will get a good going over....likely Elephant Racing setup. Re-do the interior with a more supportive driver's seat. Refreshed gauges (Hollywood Speedo) in 356 fashion. Double wrapped RS steering wheel. GT lightwt door panels. Eventually, a bigger four will power the car. Would like to keep it all 4 cylinder for the time being. I've already got a 911 sitting in the garage that tics all the 911 boxes off. I'll keep a log of the progress here with pics. This is a big, big project.....no doubt. |
cary |
Oct 23 2016, 02:35 PM
Advanced Member Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest |
Now where was I ? Next I was on to preparing the qtr. panel back corners. After looking at the taillight panel I decided a was going open up the rosette holes on the lower portion. The lower portion of the taillight panel is solid. (IMG:style_emoticons/default/smile.gif)
The cut out of the taillight portion went well. Did have one drill thru, but all in all, nice. You will find piles of seam sealer up in the inside corner. (IMG:style_emoticons/default/mad.gif) Next will be blasting it clean. I'll use garnet on the back. I'm thinking I'll try the walnuts I have for the front. See what type of finish it gives me. Weapons tray .............. |
Lo-Fi Version | Time is now: 20th April 2024 - 06:24 AM |
