911 ebrake question, years and what caliper ? |
got914? |
Feb 12 2015, 01:42 PM
Member Group: Members Posts: 133 Joined: 8-October 14 From: Niagara Member No.: 17,993 Region Association: None |
What year backing plate assembly do we need ?
Also are you using the stock 914 caliper or do you switch to the 911 ? |
914GTSTI |
Feb 12 2015, 01:52 PM
Member Group: Members Posts: 270 Joined: 16-September 07 From: Glendale AZ Member No.: 8,123 Region Association: None |
I have a set of hat's if you go with 911 SC stuff. I will not be able to use them on my build.
worn |
Feb 12 2015, 04:40 PM
can't remember Group: Members Posts: 3,155 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
What year backing plate assembly do we need ? Also are you using the stock 914 caliper or do you switch to the 911 ? You need a specific 911 wheel backing plate and bearing cover - I wanna say mid 70s will work, but I will have to look. I have quite a lot of photos of the process but have not yet posted them. I went the route of installing the thick metal stop and using VW bus cables in extended 914 tubes. Before you say it, I know (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) or at least my contribution |
worn |
Feb 12 2015, 04:41 PM
Steve |
Feb 12 2015, 08:09 PM
914 Guru Group: Members Posts: 5,585 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
PMB makes aftermarket 914-6 calipers. It's a lot less hassle than the 911 ebrake.
http://www.pmbperformance.com/914brake.html Here's alink to a how to article on the 911 ebrake conversion. http://www.914world.com/bbs2/index.php?showtopic=4909 I am running the 911 ebrake with boxster rear calipers. I had a member here weld the stop plate to my trailing arms. I am not a fan of the stop plate on the backing plate. It's not as strong as how the factory did it. |
Lo-Fi Version | Time is now: 15th May 2024 - 11:25 AM |
