> Replacement Seatbelts, any retractable belts for early models?
Tom73
post Feb 7 2005, 08:45 PM
I am sure that this has been discussed before but is there any retractable belts thatis a bolt in replacement for the early model manual belts? Thought about retrofitting later model retractable belts but there is no pocket in the firewall for mounting them. Suggestions???
tom...
lapuwali
post Feb 7 2005, 08:57 PM
Not another one!
You can get new retractable belts for the 914 from PE Parts:
Their website
Joe Bob
post Feb 7 2005, 08:59 PM
Good stuff...watch out for Lucas the owner....he's a REAL SOB...try to talk to his employees...avoid him like the plague.... (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif)
balthazar
post Feb 7 2005, 09:21 PM
P-car junkie
I heard somewhere that 944 seat belts will work. I don't remember if the early 914 cars will accept the belts or not...just something I heard... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
Tom73
post Feb 7 2005, 10:46 PM
QUOTE (lapuwali @ Feb 7 2005, 06:57 PM)
I just looked at the web site and found belts for the 911/912 and the 356 but nothing for the 914. Did a search on 914 and it came up empty.
tom...
nsyr
post Feb 7 2005, 11:02 PM
Because I Can
Yes the 944 ones will work.
lapuwali
post Feb 7 2005, 11:10 PM
Not another one!
QUOTE (Tom73 @ Feb 7 2005, 08:46 PM)
tom...
I'd call and check. They also show seats on their front page, but there's nothing on the rest of the site about it. I put a set of PE Parts belts in my previous 914 about five years ago, so they at least used to sell them.
Aaron Cox
post Feb 7 2005, 11:20 PM
Professional Tinkerer
I have PEP 914 seatbelts..... they are great.
Midtowner
post Feb 7 2005, 11:53 PM
Ooooo!
I'm installing aftermarket units today and tomorrow. You have to remove the screws at the bottom of the back panel but so far the new belt, retractor unit and bolts fit. I'm taking pictures and will post them starting tomorrow. They say you should replace the belts every five years or so. Given that mine are 32 years old, I'd say I'm long overdue. (IMG:http://www.914world.com/bbs2/html/emoticons/MDB2.gif)
Midtowner
post Feb 8 2005, 12:44 AM
Ooooo!
Tom: My apologies. Typical Newbie error. My ride already has retracting seatbelts so my pictures may not help you in your situation. (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif)
Midtowner
post Feb 8 2005, 11:16 AM
Ooooo!
Tom: On my car there is no "pocket" in the firewall. Assuming all 914's are the same, what you need is the vinyl backboard behind the seats. This bulges out to clear the retractor unit. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Joe Bob
post Feb 8 2005, 11:56 AM
Non retracting seatbelt 914 can use the retractors, just won't be original.... (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) but only a few of us on this board worry about that.....
You can mount the retractor on the floor or hollow out the back board or convert to late style seating and back piece.
dmenche914
post Feb 8 2005, 12:15 PM
There is a difference between early and late cars for the different seat belts. Early cars had non-retract belts, later cars had retract belts. The addition of the retract belts meant that Porsche had to add a place for the retract spool, they indented the fire wall in the two upper corners to fit the spool, hence the stock spool cannot fit in the same spot on an early car. (short of cutting and welding the fire wall)
Also note that the cover for the engine relay plate had to be changed at the same time, as the early cover did not clear the new bulge into the engine bay. The back pad upolstery also is slightly different, but appears it would be very easy to get around that
So what to do????
i personnally prefer the non-retract belts, they hold me inplace much better, I like the oneness with the car feeling they give. However, that makes it near impossible to reach over to open the passenger window, or dig in the glove box without removing the belt, which I perfer not to do, even when at a stop light (been hit several times badly whilest sitting at stop lights)
The possible solution is a retract unit from a car that will mount on the same bolt that the original non-retract belt mounted. There are two choices, one up top, and one below. I suspect the lower mounting of a spool would interfer with seat travel, so the upper bolt is probably the better choice.
I had an old 67 Bug that someone retrofited with retracting 3 pt. belts. I am not sure, but I think they were from a toyota or datsun pick up. Nice self contained spool with cover mounted tot eh stock upper bolt in the Bug
I think that is pretty much your option for retract belts. wrecker might be a place to start (avoid belts from cars that have been hit, cuase they may have been streched by the accident, and no longer offer the safety of a un-used belt. )
Best bet might be some of the older cars, as many modern cars hide the spool in the panels. The spool that was added to my old Bug was clearly designed to be exposed, as it had a nice plastic cover over it.
Also check out some of the Datsun, or Toyota or what ever aftermarket suppliers, thay may be of some help. Maybe some british car suppliers, like Triumph or MG, they ought to have some compact units.
Good luck in your search.
Also note, in the interest of safety, early cars added the extra 50lbs or so each side of side impact protection in the doors (early and late doors can be swapped, get the entire window and mechanism, as they differed and will not interchange, however Porsche changed the window design at a diferent time that the side impact bars, so you might be able to get by with only a new door shell, and use your old glass and mechanism, so check closely before buying) (PS I have a set of late doors with impact protection for sale, with the glass and mechanism, $80 a pair, send a PM if interested) Also consider the later cars had better trunk protection (gussets added in front of the spare tire well) and of course the last two years had the safer bumpers.
- Lo-Fi Version Time is now: 16th April 2026 - 10:25 AM
