Advantages of H-Beam rods over stock in a 2.0L |
lonewolfe |
Feb 20 2015, 02:46 PM
Senior Member Group: Members Posts: 819 Joined: 12-September 11 From: Oakland, CA Member No.: 13,549 Region Association: Northern California |
What are the advantages of H-Beam rods over stock rods in a 2.0L motor? I know the H-Beams are lighter and stronger but in terms of performance what are the advantages of using the lighter rods?
Woody |
Feb 27 2015, 04:14 PM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
The rods are 5.325. Cam is an 86b/86c on 105 degree lobe centers with a reduced base circle. Pistons are 98mm JEs with raised pins and biral cylinders.
lonewolfe |
Feb 27 2015, 04:33 PM
The rods are 5.325. Cam is an 86b/86c on 105 degree lobe centers with a reduced base circle. Pistons are 98mm JEs with raised pins and biral cylinders. I've seen those Biral cylinders on a couple of sites. Do you have any experience with them? I've not seen anyone that has used them on a 914. In theory that sound like a great option to me but some folks have said they don't stay round because the iron sleeves are too thin. Not that they've actually used them. I believe they came from the factory on some 356's and early 911's. I doubt Porsche would have used them if they were problematic and probably switched to iron to cut cost. |
Lo-Fi Version | Time is now: 20th May 2024 - 02:31 AM |
