Advantages of H-Beam rods over stock in a 2.0L |
lonewolfe |
Feb 20 2015, 02:46 PM
Senior Member Group: Members Posts: 819 Joined: 12-September 11 From: Oakland, CA Member No.: 13,549 Region Association: Northern California |
What are the advantages of H-Beam rods over stock rods in a 2.0L motor? I know the H-Beams are lighter and stronger but in terms of performance what are the advantages of using the lighter rods?
76racer |
Feb 27 2015, 12:08 PM
Newbie Group: Members Posts: 16 Joined: 19-August 11 From: Ontario, Canada Member No.: 13,463 Region Association: Canada |
Have you priced H beam rods recently? by the time you resize and rebush your own rods you're not that far off. I installed them on my 2056 and have been very happy. I am also using 96 KB pistons and a Webcam 86A. I'm pretty happy with the performance and will be adding a header system this spring. Also running Dell 40's
Joe |
lonewolfe |
Feb 27 2015, 02:14 PM
Have you priced H beam rods recently? by the time you resize and rebush your own rods you're not that far off. I installed them on my 2056 and have been very happy. I am also using 96 KB pistons and a Webcam 86A. I'm pretty happy with the performance and will be adding a header system this spring. Also running Dell 40's Joe Hi Joe! Thanks for your input! I've considered a Webcam 86A. When does the power start coming on with that cam? Is it good for street driving? Does your car idle smoothly? I thought the 86a was better suited in the higher RPM range but I may be wrong about that. I believe that's the cam RacerChris uses in his racer which leads me to think it's best at high RPM's. |
Woody |
Feb 27 2015, 03:40 PM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
Have you priced H beam rods recently? by the time you resize and rebush your own rods you're not that far off. I installed them on my 2056 and have been very happy. I am also using 96 KB pistons and a Webcam 86A. I'm pretty happy with the performance and will be adding a header system this spring. Also running Dell 40's Joe Hi Joe! Thanks for your input! I've considered a Webcam 86A. When does the power start coming on with that cam? Is it good for street driving? Does your car idle smoothly? I thought the 86a was better suited in the higher RPM range but I may be wrong about that. I believe that's the cam RacerChris uses in his racer which leads me to think it's best at high RPM's. I've had an 86a in my 2056 for years. It's street friendly and begins to make power in the 3-3500 range. I've been satisfied with it. I'm going more aggressive with my current build. 80mm crank and rods. |
Lo-Fi Version | Time is now: 9th May 2024 - 11:09 AM |
