Tuning project from Italy, Short stroke project for turbo app |
Victrix1975 |
Feb 22 2015, 05:33 AM
Newbie Group: Members Posts: 1 Joined: 22-February 15 From: Rome Member No.: 18,457 Region Association: Europe |
Hello!
I'm Antonio frome Rome; I've bought a nice 914 1.7 litre. So I started this tuning project. The basis is to start with the DPR 66mm counterweight crank (55mm bearing) I think is better have large rod bearing for turbo modification. And with turbo is not so important have big displacement. So in the reason of this I have some question..... 1- Chose of the piston and barrel; I think to use the 98 mm je piston and biral barrel from AA performance, they build this kit for long stroke crank 78/86 mm. So to fit correctly the piston which length of rod I'need? Could you advise me if exist one with 55 mm bearing for typ 4 engine with adeguate lenght? 2- Is really recommended to not go over 98 mm bore? with 103mm bore the case could crack? I'do not have experience on typ 4 to say which is the limit. Hope everyone can advise me the better chose.... tanks Antonio |
veekry9 |
Mar 7 2015, 11:05 AM
OldMember Group: Retired Members Posts: 3,068 Joined: 17-June 13 From: TO Member No.: 16,025 Region Association: Canada |
http://www.ooyyo.com/italy/used-porsche-91...1D6617C9864111/
Welcome Antonio. (IMG:style_emoticons/default/smile.gif) This is the right place,and the right questions. The heads should be rebuilt with new seats,guides,and valves if they are not cracked.Probably have to split the cases to re+re the bottom end. "Tuning"these 80hp engines requires some delicate work,there are many aspects to them that are unlike any other. As for rod length,depends on stroke and pin height,the variable being the deck height and desired head clearance. A ton of lira can be poured into these engines,6K$ for a mild build,up from there.My own opinion is to build for reliability then add a nice turbo and intercooler. (IMG:style_emoticons/default/biggrin.gif) http://www.914world.com/bbs2/index.php?showtopic=248774 http://www.914world.com/bbs2/index.php?sho...9&hl=nein14 Perhaps you've built a motor or two,if so where do you want to take your new Porsche 914? Oh yeah,have a good close look at the TX,buy the Dr's video. (IMG:style_emoticons/default/welcome.png) |
veekry9 |
Mar 7 2015, 11:20 AM
LN has the cylinders you may want to consider.
http://lnengineering.com/products.html and for the heads to go with them http://www.hamincgroup.com/type4.php As with all high performance engines,"How fast do you want to spend?" http://www.thesamba.com/vw/forum/archive/i...t-286041--.html In answer to the crank question,you are not the first to be there. Bang for buck,it's hard to not go the big engine route. |
Mar 7 2015, 02:28 PM
Resident German Group: Admin Posts: 41,622 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Lo-Fi Version | Time is now: 5th May 2024 - 11:28 AM |
