Hitting the Dyno, Should be fun.. |
Jetsetsurfshop |
Feb 22 2015, 12:39 PM
Senior Member Group: Members Posts: 814 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States |
Hey Everyone,
I have a dyno appointment coming up next week. Is there anything that will take me by surprise? The guy running the dyno just said to not forget gas. I plan on bringing, fuel, straps, fans, and my weber jet kit. Can anyone thing of anything else required? What RPM should I stop at? (IMG:style_emoticons/default/confused24.gif) My car has larger valves (48-38), duel valve springs, solid lifters and a 494 webcam. Heres more info on the car. 2258cc 10.5 to 1 Compression Ratio 40 webers Tangerine headers 98 octane fuel What do you think she'll make at the wheels? Shane |
ThePaintedMan |
Mar 6 2015, 12:04 PM
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
Very nice Shane. You should be proud of that, especially all the work you and Keith put into it.
I agree that the carbs are probably holding you back. What vents do you have in those 40s again? Are they 30mm? Eventually it would probably be prudent to get your hands on a set of 44s... or send your 40s to Racer Chris. He works magic on his that I simply can't do (mostly proprietary info that he developed over years and years of SCCA racing, but my guess is he reworks the vents and the carb throats so that they're at their very optimum.) And since he has a flow bench, he has verified that his 40s flow like 44s! I'd love to learn more about that someday. The only other thing I would imagine that is holding you back is the heads, but you mentioned that before. Still, very impressive dude. You should be proud. |
ChrisFoley |
Mar 6 2015, 04:07 PM
I am Tangerine Racing Group: Members Posts: 7,926 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
... I agree that the carbs are probably holding you back. What vents do you have in those 40s again? Are they 30mm? Eventually it would probably be prudent to get your hands on a set of 44s... or send your 40s to Racer Chris. ... primary venturis should be 36mm, but a stock 40IDF doesn't work all that well with venturis so big. The carb inlet diameter is too small. I can fix that. |
Jetsetsurfshop |
Mar 6 2015, 04:45 PM
... I agree that the carbs are probably holding you back. What vents do you have in those 40s again? Are they 30mm? Eventually it would probably be prudent to get your hands on a set of 44s... or send your 40s to Racer Chris. ... primary venturis should be 36mm, but a stock 40IDF doesn't work all that well with venturis so big. The carb inlet diameter is too small. I can fix that. I did the 34 venturis kit from CB. We did it a while back and the car does like it better. Called Chris to modify the carbs but I was spending so much on the car at that time. Needed to stop the bleeding. Not that it was to expensive, I didn't want to spend anything after the engine build. maybe one day we will get them done right. |
Lo-Fi Version | Time is now: 19th May 2024 - 07:41 PM |
