Seeking comments about planned 1.9L rebuild .., .. and recap of my productive weekend |
Mockmaw |
Jun 3 2003, 08:20 PM
Member Group: Members Posts: 163 Joined: 18-March 03 From: Berkeley/San Diego, CA Member No.: 438 |
It was a productive 914 weekend, I sure got a lot done. I sanded, stained, and finished my custom 'center console' that houses an 8" JL sub. I dropped the engine and transmission in record time. Fabricated an engine stand and then began a very long process of labeling and disassembling the whole thing. Took the components I plan on reusing down to the machine shop to have them cleaned and spec-ed. After a solid recommendation, I decided to use a small shop called The Bug Patch located in Santee. Nice and friendly guy that appears to really know his way around TIV's.
Downside of the weekend: Someone stole the amp out of the front trunk of my car. Probably an inside job from the shop where I just had work done. I'd be pissed but it's just stuff.. I can imagine far worse things happening to my car or me. Soo.. I'm beginning to finalize the plans for my engine rebuilding, this is basically what I'm sitting on, the great plan being: 1.7L Case 66mm Crank and Rods 96mm P+Cs 1.8L Heads with heavier valve springs (with limited porting/polishing) 42x36 Valves Eagle Cam (.410" Lift, 278*) New 'Lightweight' Lifters Dual Weber 40's Mallory Unilite w/ Vac. Advance Header System (Kerry Hunter or Eurorace) Compression between 7.5:1 and 8.5:1 (still need to think about that) The goal is to have a really fun street car and continue the learning process. Sorry guys, PEFI is out and Carbs are in for right now. So my string of questions (as usual): 1. Thoughts, comments, opinions? Anyone think I'm making a huge mistake? 2. Thoughts on the Eagle Cam? I've heard good things about them so why pay the higher price for the Web-Cams? Will this be too much cam? Not enough? 3. Will I need new pushrods or can I use my old 1.7L ones? 4. Do the 42x36 valve sizings match well with the components that I'm looking at? 5. What kind of performance differences will I see in the compression range that I listed above? I'm looking for the optimal balance between performance and gas price/engine heat. Think that's it for now, let me know if there're any critical details that I may have forgotten to address. |
cgnj |
Jun 3 2003, 10:36 PM
Senior Member Group: Members Posts: 623 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None |
Hi,
Bug patch did my 2.0 heads. They required a little welding in the chamber (dropped valve guide). They did very good work. You are also near Headflow Masters. You may want to comparison shop there. I have never used them, but many people of STF have used them. CGNJ |
Lo-Fi Version | Time is now: 26th May 2024 - 06:07 PM |
