Factory 2.0 L Exhaust Nut vs Copper Nut, A Compairson of the Two |
914Sixer |
Feb 26 2015, 10:12 PM
914 Guru Group: Members Posts: 8,882 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
This might explain difference in cost between the two. The 2.0 nut is used and the copper is new. Note the copper one has elongated hole.
Attached image(s) |
Cap'n Krusty |
Feb 27 2015, 12:23 PM
Again, you're joining the ranks of those who call those things "copper" nuts. They're NOT copper, they're STEEL, with a copper plating. Clearing out the "pinch" makes them regular nuts with a hefty price tag.
The Cap'n |
JamesM |
Feb 27 2015, 12:58 PM
Senior Member Group: Members Posts: 1,900 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Again, you're joining the ranks of those who call those things "copper" nuts. They're NOT copper, they're STEEL, with a copper plating. Clearing out the "pinch" makes them regular nuts with a hefty price tag. The Cap'n Force of habit as that is how they are advertised EVERYWHERE. Personally if I can't find OEM ones I will go with these: http://vwparts.aircooled.net/ACN-Flanged-R...-p/acn-nuts.htm REALLY nice when dealing with larger OD header stubs. |
pete000 |
Feb 27 2015, 06:51 PM
Senior Member Group: Members Posts: 1,885 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
Again, you're joining the ranks of those who call those things "copper" nuts. They're NOT copper, they're STEEL, with a copper plating. Clearing out the "pinch" makes them regular nuts with a hefty price tag. The Cap'n Force of habit as that is how they are advertised EVERYWHERE. Personally if I can't find OEM ones I will go with these: http://vwparts.aircooled.net/ACN-Flanged-R...-p/acn-nuts.htm REALLY nice when dealing with larger OD header stubs. These are the ones I went with. They worked fine with my SSi's and were no trouble to install. |
Lo-Fi Version | Time is now: 17th May 2024 - 04:55 PM |
